ospf and static route redistribution
R Manjunatha
Level 3
Level 3
I'm unable to ping from the R2 router IP address 172.16.0.1 similarly from the R5 router as well. I configured the OSPF and static route in the R12 router and redistributed it.
R12 ROUER
interface Ethernet0/0
ip address 172.16.1.104 255.255.255.0
duplex auto
interface Ethernet0/1
ip address 172.16.10.105 255.255.255.0
duplex auto
interface Ethernet0/2
ip address 172.16.0.2 255.255.255.0
duplex auto
interface Ethernet0/3
no ip address
shutdown
duplex auto
router ospf 1
redistribute static subnets
network 172.16.0.0 0.0.255.255 area 0
default-information originate always
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Ethernet0/0
ip route 0.0.0.0 0.0.0.0 Ethernet0/1
ip route 0.0.0.0 0.0.0.0 172.16.0.1
R2 Router
version 15.7
hostname R3-Spoke1
boot-start-marker
boot-end-marker
vrf definition cust1
rd 1:1
route-target export 1:1
route-target import 1:1
address-family ipv4
exit-address-family
vrf definition cust2
rd 2:2
route-target export 2:2
route-target import 2:2
address-family ipv4
exit-address-family
no aaa new-model
clock timezone CET 1 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip domain lookup
ip domain name cisco.com
ip cef
no ipv6 cef
mpls ldp loop-detection
crypto pki trustpoint CA
enrollment url http://172.16.1.1:80
password
fingerprint E0AFEFD7F08070BAB33C8297C97E6457
subject-name cn=R3-spoke.cisco.com,OU=FLEX,O=Cisco
revocation-check crl none
crypto pki certificate map mymap 10
subject-name co ou = flex
crypto pki certificate chain CA
redundancy
crypto ikev2 authorization policy default
route set interface
crypto ikev2 profile default
match certificate mymap
identity local fqdn R3-Spoke.cisco.com
authentication remote rsa-sig
authentication local rsa-sig
pki trustpoint CA
dpd 60 2 on-demand
aaa authorization group cert list default default
crypto ipsec profile default
set ikev2-profile default
interface Tunnel0
ip address negotiated
mpls bgp forwarding
tunnel source Ethernet0/0
tunnel destination 172.16.0.1
tunnel protection ipsec profile default
description WAN
ip address 172.16.1.103 255.255.255.0
duplex auto
description LAN
no ip address
no ip unreachables
duplex auto
interface Ethernet0/1.10
encapsulation dot1Q 10
vrf forwarding cust1
ip address 192.168.113.1 255.255.255.0
interface Ethernet0/1.20
encapsulation dot1Q 20
vrf forwarding cust2
ip address 192.168.123.1 255.255.255.0
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
router bgp 100
bgp log-neighbor-changes
neighbor 10.0.0.1 remote-as 10
neighbor 10.0.0.1 ebgp-multihop 255
neighbor 10.0.0.1 update-source Tunnel0
address-family ipv4
neighbor 10.0.0.1 activate
exit-address-family
address-family vpnv4
neighbor 10.0.0.1 send-community both
exit-address-family
address-family ipv4 vrf cust1
redistribute connected
exit-address-family
address-family ipv4 vrf cust2
exit-address-family
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.1.104
ip route 10.0.0.1 255.255.255.255 Tunnel0 name workaround
ip route 172.16.0.1 255.255.255.255 172.16.1.1 name FlexHUB
R5 Router
rd 1:1
address-family ipv4
exit-address-family
rd 2:2
address-family ipv4
exit-address-family
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
password
subject-name cn=R4-Spoke.cisco.com,OU=Flex,O=Cisco
redundancy
route set interface
identity local fqdn R4.cisco.com
pki trustpoint CA
dpd 60 2 on-demand
virtual-template 1
interface Loopback100
ip address 192.168.114.1 255.255.255.0
interface Loopback101
ip address 192.168.124.1 255.255.255.0
interface Tunnel0
mpls bgp forwarding
description WAN
ip address 172.16.10.104 255.255.255.0
duplex auto
description LAN
ip address 192.168.104.1 255.255.255.0
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
router bgp 100
address-family ipv4
exit-address-family
exit-address-family
exit-address-family
exit-address-family
no ip http server
ipv6 ioam timestamp
R1 ROUTER
hostname R1-HUB
boot-start-marker
boot-end-marker
rd 1:1
rd 2:2
aaa new-model
aaa authorization network default local
aaa session-id common
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
enrollment url http://172.16.0.2:80
password
subject-name CN=R1-HUB.cisco.com,OU=FLEX,OU=VPN,O=Cisco Systems,C=US,L=Linux
rsakeypair R1-HUB.cisco.com 2048
auto-enroll 95
redundancy
pool mypool
banner ^CC Welcome ^C
def-domain cisco.com
route set interface
match identity remote fqdn domain cisco.com
identity local dn
pki trustpoint CA
dpd 60 2 on-demand
virtual-template 1
interface Loopback0
description VT source interface
ip address 10.0.0.1 255.255.255.255
description WAN
ip address 172.16.0.1 255.255.255.0
duplex auto
description LAN
ip address 192.168.100.1 255.255.255.0
duplex auto
ip address 192.168.110.1 255.255.255.0
duplex auto
ip address 192.168.111.1 255.255.255.0
duplex auto
interface Virtual-Template1 type tunnel
ip unnumbered Loopback0
ip nhrp network-id 1
ip nhrp redirect
mpls bgp forwarding
router bgp 10
bgp listen range 0.0.0.0/0 peer-group mpls
bgp listen limit 5000
neighbor mpls peer-group
neighbor mpls remote-as 100
neighbor mpls transport connection-mode passive
neighbor mpls update-source Loopback0
address-family ipv4
redistribute static route-map cust2
neighbor mpls activate
neighbor mpls next-hop-self
exit-address-family
neighbor mpls send-community both
exit-address-family
ip local pool mypool 10.1.1.1 10.1.1.254
no ip http server
ip route 0.0.0.0 0.0.0.0 172.16.0.2 name route_to_internet
Not exactly sure what you're trying to accomplish and looks like a lot going on. A couple things I notice:
R5 doesn't have a route to R2<->R12s P2P network
R12 has several default routes
Putting routes into OSPF wont accomplish anything towards the solution as I don't see OSPF configured on R2 or R5 (or R1) so its unaffected by OSPF.
Can you put a static route on R5 towards R12 pointing to wards the R12<->R2 P2P segment and show your routing table on R2 and R5?
-David
hard to figure out. Post the full running configs of all 10 routers, so we can lab this up...
fniccola
ciao R Manjunatha,
only a fiew questions to understand better your environment
1. on R2 there is a static route with this next hop
why you are pointing to that IP? on the other end we have 172.16.1.104
can you share these outputs:
show ip arp inter eth0/0
show ip route 172.16.0.1
2. on R5 there is a static route with this next hop
why you are pointing to that IP? on the other end we have 172.16.10.105
I'm  Replicating the environment in my lab, I'll share my results
TKK
FabioN
R Manjunatha
Level 3
Level 3
There was a routing issue, and that has been resolved after configuring the static IP address, and now interface tunnel 0 is showing down. I can ping the WAN link from spokes to hub.
This is the mpls over flex VPN configuration, which was referred to in the Cisco documentation as shown below the link.
Cisco Content Hub - Configuring MPLS over FlexVPN
R3-Spoke1#sh ip int b
Ethernet0/0 172.16.1.103 YES NVRAM up up
Ethernet0/1 unassigned YES NVRAM up up
Ethernet0/1.10 192.168.113.1 YES NVRAM up up
Ethernet0/1.20 192.168.123.1 YES NVRAM up up
Ethernet0/2 unassigned YES NVRAM administratively down down
Ethernet0/3 unassigned YES NVRAM administratively down down
Tunnel0 unassigned YES NVRAM up down
R3-Spoke1#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
IPv6 Crypto ISAKMP SA
R3-Spoke1#sh crypto ipsec sa
interface: Tunnel0
Crypto map tag: Tunnel0-head-0, local addr 172.16.1.103
protected vrf: (none)
local ident (addr/mask/prot/port): (172.16.1.103/255.255.255.255/47/0)
remote ident (addr/mask/prot/port): (172.16.0.1/255.255.255.255/47/0)
current_peer 172.16.0.1 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 172.16.1.103, remote crypto endpt.: 172.16.0.1
plaintext mtu 1500, path mtu 1500, ip mtu 1500, ip mtu idb Ethernet0/0
current outbound spi: 0x0(0)
PFS (Y/N): N, DH group: none
configuration :-
R3-Spoke1#sh run
Building configuration...
Current configuration : 3043 bytes
! Last configuration change at 08:07:17 CET Fri Feb 2 2024
version 15.7
hostname R3-Spoke1
boot-start-marker
boot-end-marker
rd 1:1
address-family ipv4
exit-address-family
rd 2:2
address-family ipv4
exit-address-family
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
password
redundancy
route set interface
pki trustpoint CA
dpd 60 2 on-demand
interface Tunnel0
mpls bgp forwarding
description WAN
duplex auto
description LAN
no ip address
no ip unreachables
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
router bgp 100
address-family ipv4
exit-address-family
exit-address-family
exit-address-family
exit-address-family
no ip http server
ip route 10.0.0.1 255.255.255.255 Ethernet0/0
ip route 172.16.0.1 255.255.255.255 172.16.1.104 name FlexHUB
R4-Spoke#sh run
Current configuration : 2985 bytes
! Last configuration change at 07:20:34 CET Fri Feb 2 2024
version 15.7
hostname R4-Spoke
boot-start-marker
boot-end-marker
rd 1:1
address-family ipv4
exit-address-family
rd 2:2
address-family ipv4
exit-address-family
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
password
redundancy
route set interface
pki trustpoint CA
dpd 60 2 on-demand
virtual-template 1
interface Tunnel0
mpls bgp forwarding
description WAN
duplex auto
description LAN
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
router bgp 100
address-family ipv4
exit-address-family
exit-address-family
exit-address-family
exit-address-family
no ip http server
ip route 172.16.0.1 255.255.255.255 172.16.10.105 name FlexHUB
ipv6 ioam timestamp
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input none
R1-HUB#sh run
Current configuration : 3141 bytes
! Last configuration change at 07:17:27 CET Fri Feb 2 2024
version 15.7
hostname R1-HUB
boot-start-marker
boot-end-marker
rd 1:1
rd 2:2
aaa new-model
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
password
auto-enroll 95
redundancy
pool mypool
route set interface
identity local dn
pki trustpoint CA
dpd 60 2 on-demand
virtual-template 1
interface Loopback0
description WAN
duplex auto
description LAN
duplex auto
duplex auto
duplex auto
ip nhrp redirect
mpls bgp forwarding
router bgp 10
address-family ipv4
exit-address-family
exit-address-family
no ip http server
ipv6 ioam timestamp
route-map cust1 permit 10
match tag 666
route-map cust2 permit 10
match tag 667
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
end
R1-HUB#
