Can ASA operates Multiple context mode?
sir_yrwins
Can CISCO ASA operates in Multiple Context Mode?
I know route and transparent mode can be operates. but what about Multiple mode ?
6 Replies 6
balaji.bandi
you mean both transparent and route in context mode :
look below guide lines :
https://www.cisco.com/c/en/us/td/docs/security/asa/asa918/asdm718/general/asdm-718-general-config/interface-routed-tfw.html#ID-2214-00000004
BB
Giuseppe Larosa
Hello @sir_yrwins ,
you need a specific license if you want to run more then 4-5 contexts . You can have some contexts in routed mode and a few in transparent mode with specific limitations.
Hope to help
Giuseppe
Hello
FYI-
ASA supports Single or Multiple mode as you are aware
  • In single mode you cannot create virtual firewalls.
  • In multiple mode you can create virtual firewalls.
  • Each virtual firewall is called a context.
  • Number of context that you can create depends on the license ( as stated by @Giuseppe Larosa )
  • By default there are two built
Kind Regards
Paul
Ruben Cocheno
@sir_yrwins
Let's say that you have 2 Firewall contexts (CTX1 and CTX2), and you must have 2 contexts by default as parf of the base license.
CTX1 - Transparent Mode
CTX2 - Routed Mode
ASA1 to be active for CTX1 and standby for CTX2
ASA2 to be Standby for CTX1 and active for CTX2
OR
ASA2 to be Standby for CTX1 and Active for CTX2
Convert ASA to multicontext
CiscoASA(config)# mode multiple
WARNING: This command will change the behavior of the device
WARNING: This command will initiate a Reboot
Proceed with change mode? [confirm]
Convert the system configuration? [confirm]
The old running configuration file will be written to flash
Converting the configuration - this may take several minutes for a large configuration
The admin context configuration will be written to flash
The new running configuration file was written to flash
Security context mode: multiple
CiscoASA(config)#
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
johnlloyd_13
Level 9
Level 9
hi,
yes, the ASA can operate in multiple mode. issue a 'show mode' to confirm.
ASA comes with 2 security context by default and you'll need to buy a license if you'll need more.
issue a 'show version' to check the available context count.
use the 'mode multiple' in global config mode and it will ask to reboot to take effect.
all existing config will go to the 'admin' context.
