Can Cisco Router 2951 is suitable for 100 Mbps MPLS link
amitsharma4534
I want a router to terminate 100Mbps MPLS link on it. Can Cisco 2951 will be suitable for this or i have to go on to 3900 series or 7200 series
Amit Sharma
Leo Laohoo
2951 will support up to 296 Mbps, half duplex, un-encrypted traffic.
If you want to have a router that can handle >100 mbps, full duplex and full encryption then it's got to be the 3925.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Assuming your hand-off is Ethernet, 100 Mbps (full duplex), for 64 byte size packets, requires 297.6 Kpps.  Going by this alone, all the 2900 series routers are documented as having more than 300 Kpps in a RFC 2544 test (see Table 1, 2nd page of attachment).  However, for 100 Mbps, Cisco recommends minimally a 3925 (see figure 1, on last page of attachment), but that guarantees performance for multiple services while running at 100 Mbps (duplex) bandwidth.  If you expect your service feature needs to be less and/or average traffic utilization less, you should be able to downsize accordingly.  I've often found you can downsize one or two sizes from the Cisco recommendation.  (Again, router sizing depends much on your expected usage.)
