Can connect to router through VPN Client but cannot access any private LAN machines
mirsalaradili
Hello all,
I have a change in my network where I had to setup a public IP directly on my internet interface. I am hosting Crypto IPSec on my router to provide VPN service to my employees. After setting the public IP on my interface gig0/1 and making changes to the ip nat and ip routing, I am able to connect to the router and get authenticated, but I am not able to ping or access any of the LAN machines. Below is my config:
Building configuration...
Current configuration : 16288 bytes
! Last configuration change at 12:08:24 TIME Sat Sep 21 2013 by admin
version 15.1
service password-encryption
hostname WRouter
boot-start-marker
boot system flash c1900-universal-mz.SPA.151-3.T1.bin
boot system flash c1900-universalk9-mz.SPA.151-3.T1.bin
boot-end-marker
logging buffered 51200 warnings
enable secret 5 XXXXXXXXXXXXXXXXXXXxx
enable password 7 XXXXXXXXXXXXXXXXX
aaa new-model
aaa authentication login default enable
aaa authentication login VPNUser local
aaa authorization network VPNGroup local
aaa session-id common
clock timezone TIME -4 0
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.0.0.1 10.0.0.149
ip dhcp excluded-address 10.0.20.1 10.0.20.10
ip dhcp excluded-address 10.0.0.250 10.0.0.254
ip dhcp pool Internal
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.1
   dns-server 10.0.0.3 8.8.8.8
ip dhcp pool staticprinter
   host 10.0.0.238 255.255.255.0
   hardware-address 0080.7784.8180
ip dhcp pool WIRELESS
   network 10.0.20.0 255.255.255.0
   default-router 10.0.20.1
   dns-server 10.0.20.1 8.8.8.8
   domain-name ppsinfotech.com
crypto ctcp port 10000
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp client configuration group VPN
key XXXXXXXXXXXXX
dns 10.0.0.3 4.2.2.2
domain contoso.com
pool vpnpool
acl split
split-dns contoso.com
netmask 255.255.255.0
crypto ipsec security-association idle-time 1200
crypto ipsec security-association replay disable
crypto ipsec transform-set tset esp-aes esp-md5-hmac
crypto dynamic-map dmap 10
set transform-set tset
reverse-route
crypto map dmap client authentication list VPNUser
crypto map dmap isakmp authorization list VPNGroup
crypto map dmap client configuration address respond
crypto map dmap 10 ipsec-isakmp dynamic dmap
interface Loopback0
ip address 10.11.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.0.2.2 255.255.255.0
ip nat outside
duplex auto
speed auto
shutdown
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 10.10.10.10 255.255.255.0
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
ip address 50.112.237.70 255.255.255.252
ip access-group testin in
ip nat outside
ip policy route-map VPN-Client
duplex full
speed 100
crypto map dmap
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
switchport access vlan 30
interface GigabitEthernet0/1/0
switchport access vlan 10
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface Vlan1
no ip address
interface Vlan10
ip address 10.0.0.1 255.255.255.0
ip nat inside
interface Vlan20
ip address 10.0.6.3 255.255.255.0
interface Vlan30
ip address 10.0.20.1 255.255.255.0
ip nat inside
ip local policy route-map VPN_USERS_RM
ip local pool vpnpool 10.0.5.10 10.0.5.150
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat pool G1 50.112.237.111 50.112.237.111 prefix-length 27
ip nat inside source route-map NAT2 pool G1 overload
ip nat inside source static 50.112.237.70 50.112.237.110
ip route 0.0.0.0 0.0.0.0 50.112.237.69
ip access-list extended VPN_USERS
permit udp any eq isakmp any
permit udp any any eq isakmp
permit udp any eq non500-isakmp any
permit udp any any eq non500-isakmp
permit tcp any eq 10000 any
permit tcp any any eq 10000
permit icmp host 10.0.1.2 any
ip access-list extended split
permit ip 10.0.0.0 0.0.0.255 10.0.5.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 101 deny   ip 10.0.0.0 0.0.0.255 10.0.5.0 0.0.0.255
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
access-list 101 permit ip 10.0.20.0 0.0.0.255 any
access-list 102 deny   ip 10.0.0.0 0.0.0.255 10.0.5.0 0.0.0.255
access-list 102 permit ip 10.0.0.0 0.0.0.255 any
access-list 102 permit ip 10.0.20.0 0.0.0.255 any
access-list 103 permit ip 10.0.5.0 0.0.0.255 any
access-list 105 permit tcp host 10.0.0.4 eq www any
access-list 105 permit tcp host 10.0.0.4 eq 3400 any
access-list 105 permit tcp host 10.0.0.94 eq www any
access-list 105 permit ip 10.0.0.0 0.0.0.255 10.0.5.0 0.0.0.255
access-list 150 permit tcp any any eq 10000
access-list 151 permit ip 10.0.0.0 0.0.0.255 10.0.5.0 0.0.0.255
route-map REMOTE permit 10
match ip address 151
set ip next-hop 50.112.237.69
route-map VPN_USERS_RM permit 10
match ip address VPN_USERS
route-map PBR permit 10
match ip address 105
route-map VPN permit 10
match ip address 150
route-map VPN-Client permit 10
match ip address 103
set ip next-hop 10.11.0.2
route-map NAT2 permit 10
match ip address 102
match interface GigabitEthernet0/1
route-map NAT1 permit 10
match ip address 101
match interface GigabitEthernet0/0
control-plane
My internal network: 10.0.0.x
My internal wireless network: 10.0.20.x
My VPN pool: 10.0.5.x
My internet interface: Gig0/1
I am using one of my available public IPs for internal internet access for which i have created a NAT and route-map. The same for my VPN connection.
Note: IP addresses are only for reference and have been changed for security purposes.
Please advise...
Salar
pieterh
ip nat outside
duplex auto
speed auto
shutdown
Last line Will be your trouble?
I don't believe that is the problem. I am not using my gig0/0 in this scenario. This used to be one of my two internet lines, but since i am using Fiber now i only use gig0/1. That is why 0/0 is shutdown. Any other ideas? The problem is that the VPN users can be authenticated through gig0/1 but cannot ping any of the LAN servers (subnet 10.0.0.x).
I think it may be related to how i have configured my VPN public ip 1-to-1 NAT on the router. (
ip nat inside source static 50.112.237.70 50.112.237.110)
is there something wrong with the way this is setup?
Any advise would be much appreciated
Salar
