Can Dynamic NAT but not Static NAT on 877
Peter Brady
Hi All,
This should be simple, I just think I've been staring at it for too long and can't see what I'm missing.
I've  got an 877 WAN router that I'm provisioning and I can't configure a static map to let an outside connection talk into an internal box via SSH.  What  I've currently got:
  1. I can ping, and ssh when configured, into the 877 from outside.
  2. The 877 can ping outside from the terminal
  3. The 877 knows, via static routes, about all my internal subnets, it can ping devices
  4. I can ping, and ssh, the 877 from inside
  5. The 877 is running DNAT for internal hosts fine to share the net connection.
And the kicker: I've got a similar 877, but with a simpler single internal subnet, at another site that is doing exactly this perfectly.  Same OS version, same ISP, same connection plan.  I'm offsite right now and the device is powered off so I can't post output of show, debug etc.  I've tried:
  1. The routing table looks OK, my default gateway is upstream to the ISP and all the static routes are in place for the local subnets
  2. I've stripped out most of the ACLs
  3. I've stripped out the firewall
  4. Looking at the nat translations table there appears to be a static map in place when connecting in from the outside world but is not arriving at the destination box.  FYI this destination box is currently  available from another WAN link and I checked the firewall policies on  it and I don't think this is the issue.  Haven't done a packet dump at that end yet to see if its getting anything though.
Like I said, I think I just can't see my mistake right now.  Any help would be appreciated and the running config is below.  It is very much a minimal configuration to try to isolate my NAT mistake.
Thanks in advance,
-pete
version 12.4
no service pad
service password-encryption
hostname orcus
ip domain name wmawater.com.au
ip name-server 192.168.70.17
ip name-server 192.168.70.18
scheduler max-task-time 5000
ntp clock-period 17182119
ntp server 192.168.70.18 source Vlan1
ntp server 192.168.70.17 source Vlan1
! Turn off host name lookups unless we want to
no ip domain-lookup
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 <password>
no aaa new-model
dot11 syslog
ip cef
username root privilege 15 secret 5 <password>
archive
log config
  hidekeys
no ip ftp passive
ip ssh time-out 60
ip ssh authentication-retries 2
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
ip address 192.168.60.3 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username <user> password 7 <password>
! Set the IP routing and default routes
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 192.168.70.0 255.255.255.0 192.168.60.1
ip route 192.168.80.0 255.255.255.0 192.168.60.1
ip route 192.168.90.0 255.255.255.0 192.168.60.1
ip route 192.168.100.0 255.255.255.0 192.168.60.1
ip route 192.168.120.0 255.255.255.0 192.168.60.1
ip route 192.168.130.0 255.255.255.0 192.168.60.1
ip route 192.168.140.0 255.255.255.0 192.168.60.1
! ip http server
! ip http access-class 1
! ip http authentication local
! ip http secure-server
! ip http timeout-policy idle 60 life 86400 requests 10000
! Configure NAT
ip nat inside source list 2 interface Dialer0 overload
ip nat inside source static tcp 192.168.70.34 22 interface Dialer0 22
! Permit all access from local subnets with no restrictions
access-list 2 permit 192.168.0.0 0.0.255.255
! Dialer access so we allow anything to access it
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
! Lock down the local access to restrict command line access for
! configuration
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input ssh
end
johnlloyd_13
Level 9
Level 9
hi peter,
your inside device 192.168.70.34 is on a different subnet with your LAN default gateway 192.168.60.3/24. you may want to reassign its IP.
Doh, thanks.  Yes your are probably right on that.  I'm offsite for a day or so but will try when I get back.  Production verses development VLANs got me then I think.
-pete
Hi Peter,
Glad to be some assistance to you. Do rate if post helped on your issue.
Hi John,
Turns out it wasn't the subnet but your suggestion caused me to look at my configuration differently.  I was not explicitly enabling the firewall to allow incoming packets that did not originate on my network from coming in.
Thanks for the suggestion though.
-pete
