Can I add a 2nd Ethernet port to a Cisco 2620 router?
whiteford
I have a Cisco 2620 with 2 x WIC-1T cards and one ethernet, is there a way I can add a 2nd ethernet port?
garytayl
Level 3
Level 3
That router has two WIC slots and one Network Module therefore, you might be able to use NM-1E or NM-4E but go ahead and check the documentation and also find out if those modules are still available:
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/OvrNetM.html
Hope it helps.....
Gary
