Can I change FTP port number in CIsco router
sujitkr7cisco
I what to change default FTP port 21 to ant unresrved Port or nay port . How is it possible in Cisco 1800 and 1600 router.
Collin Clark
Do you mean to and from the router (eg copying new IOS) or do you mean NATing through the router?
Dear Collin,
i wnat to the ftp user access remotly to the different portd ,not through default FTP port -21.which is the best and most secure.
Thanks for reply.
Sujeet
OK- Let's assume the server is running on port 21, but you want users to connect to 2121 for FTP. You'll need to create a NAT translation.
ip nat inside source static tcp 192.168.0.1 21 interface [public ip] 2121
Don't forget to allow TCP 2121 in your ACL.
Hope that helps.
