11-01-2011 09:32 AM - edited 03-04-2019 02:07 PM
I currently have 2 WAN links, a 20MB Ethernet BGP MPLS and a bonded T1. I have a 2800 at each end configured to automatically fail over to the T1 in the event that the MPLS goes gown. I put a high AD on the T1 connection with static routes. If the MPLS goes down the T1 does kick in, however users are dropped from their applications and VOIP calls are disconnected.
I was looking into Fat Pipe appliances and they supposidly will fail over a connection without any packet loss - therefore not dropping a VOIP call or kicking anyone off the database application. In addition they will provide aggregated bandwidth.
Is there any way to achieve a similar failover without packet loss with just the routers? Do I really need to purchase the Fat Pipe to achieve this? Are there any alternatives?
Thanks.
11-01-2011 09:45 AM
Before you purchase the "Fat Pipe" appliance, you may want to talk to your ISP and and use a routing protocol (BGP) to peer with them and test it to see if you get better results.
11-01-2011 09:49 AM
I am already using BGP.
11-02-2011 02:53 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What QoS, if any, is configured for the T1 path?
How many T1s are bonded and bonded how?
What model(s) 2800? What IOS version?
