Can I enable the GUI for WAN configuration of a 1921 router?
mwilliams
I have a Cisco 1921 in place with the security IOS so it is also acting as a firewall.
I am wondering if I can enable the GUI so I can configure it remotely. Is that possible?
johnlloyd_13
Level 9
Level 9
hi morris,
yes, you can do this via Cisco's SDM or CCP.  see URL and initial router conifg below. note that SDM is the old GUI and CCP is the latest.
http://www.cisco.com/en/US/products/sw/secursw/ps5318/index.html
http://www.cisco.com/en/US/products/ps9422/index.html
Router(config)#ip http server    OR
Router(config)#ip http secure-server
Router(config)#ip http authentication local
Router(config)#ip http timeout-policy idle 600 life 86400 requests 10000
Router(config)#username privilege 15 secret
Router(config)#line vty 0 4
Router(config-line)#privilege level 15
Router(config-line)#login local
johnlloyd_13
Level 9
Level 9
hi morris,
John,
Thanks again!!!! I will run these commands tomorrow. I can do most of the configs I need using the CLI, but there is something reassuring having the GUI as well.
I'll follow up with you again after I get this working tomorrow.
Thanks!
hi morris,
sure just let this forum know if it worked.
on a personal note, GUI is nice but CLI is still the way to go.
