3750X, Code 12.2-25.see2
MikeCarter1
Good Day Everyone.....
Recently, we had a 3750X stack of 9 switches reload with no information as to why. Our syslog server received no spurious errors regarding the cause nor did the location lose power. The UPS to which it is attached logged no glitches relating to power. Other cisco devices (router, other switches not in the stack) did not reload. No one was in the MDF during this time.
We self insure these line of switches so a TAC case is not an option at this time. I was curious if anyone knew of any forensic tools that I could try in an attempt to narrow down the cause. BugSearch returned no help.
Thank you for your time.
5 Replies 5
Leo Laohoo
Hi Mike,
What do you mean by the title of this thread?   3750X will not boot with IOS version 12.2(25).  The lowest IOS for the 3750X is the 12.2(53)SE2 and nothing earlier than that.
Regarding the cause of the reboot, can you please post the complete output for the following command:
1.  sh version;
2.  sh switch detail;
3.  dir flashNNN:      < ---  NNN = the number of switches in your stack.  If you have, say 4, then you need to do "dir flash1:", "dir flash2:", "dir flash3:" and "dir flash4:".
4.  sh log
Interesting results from dir flash7: and dir flash9:
Also, I believe these to be regular 3750's and not X's. My bad.
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 12:55 by yenanh
Image text-base: 0x00003000, data-base: 0x010272D8
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
XXXXmstack uptime is 3 days, 21 hours, 8 minutes
System restarted at 12:03:47 est Sun Dec 11 2011
System image file is "flash:c3750-ipbasek9-mz.122-25.SEE2/c3750-ipbasek9-mz.122-25.SEE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-24TS (PowerPC405) processor (revision M0) with 118784K/12280K bytes of memory.
Processor board ID CAT1114ZJZ1
Last reset from power-on
2 Virtual Ethernet interfaces
168 FastEthernet interfaces
62 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1A:E3:96:39:00
Motherboard assembly number     : 73-9677-10
Power supply part number       : 341-0034-01
Motherboard serial number       : CAT11145774
Power supply serial number     : PHI1022B4K1
Model revision number           : M0
Motherboard revision number     : B0
Model number                   : WS-C3750-24TS-S
System serial number           : CAT1114ZJZ1
Top Assembly Part Number       : 800-25857-02
Top Assembly Revision Number   : F0
Version ID                     : V05
CLEI Code Number                : CNMV100CRE
Hardware Board Revision Number : 0x01
Switch   Ports Model             SW Version             SW Image
     1   24     WS-C3750G-24T     12.2(25)SEE2          C3750-IPBASEK9-M
     2   24     WS-C3750G-24T     12.2(25)SEE2           C3750-IPBASEK9-M
     3   26     WS-C3750-24TS     12.2(25)SEE2           C3750-IPBASEK9-M
     4   26     WS-C3750-24TS     12.2(25)SEE2           C3750-IPBASEK9-M
     5   26     WS-C3750-24TS     12.2(25)SEE2           C3750-IPBASEK9-M
     6   26     WS-C3750-24TS     12.2(25)SEE2           C3750-IPBASEK9-M
     7   26     WS-C3750-24TS     12.2(25)SEE2           C3750-IPBASEK9-M
*   8   26     WS-C3750-24TS     12.2(25)SEE2           C3750-IPBASEK9-M
     9   26     WS-C3750-24TS     12.2(25)SEE2           C3750-IPBASEK9-M
Switch 01
Switch Uptime                   : 3 days, 21 hours, 0 minutes
Base ethernet MAC Address       : 00:1B:0D:BF:1E:00
Motherboard assembly number     : 73-9679-10
Power supply part number       : 341-0048-03
Motherboard serial number       : CAT11235C2F
Power supply serial number     : DTN110931TA
Motherboard revision number     : C0
Model number                   : WS-C3750G-24T-S
System serial number           : FHK1134Z01G
Top assembly part number       : 800-25855-01
Top assembly revision number   : G0
Version ID                     : V05
CLEI Code Number               : COMR100BRA
Switch 02
Base ethernet MAC Address       : 00:18:BA:F2:F0:00
Motherboard serial number       : CAT10325U7L
Power supply serial number     : DTH10284AY4
Model revision number           : L0
System serial number           : CAT1033ZJJ9
Top assembly revision number   : E0
Version ID                     : V05
Switch 03
Base ethernet MAC Address       : 00:1B:90:6B:74:00
Motherboard serial number       : CAT11155109
Power supply serial number     : DTH111210UH
System serial number           : CAT1115NHL5
Top assembly part number       : 800-25857-02
Top assembly revision number   : F0
Version ID                      : V05
Switch 04
Base ethernet MAC Address       : 00:1B:90:6B:9C:00
Motherboard serial number       : CAT111550VW
Power supply serial number     : DTH111210FB
System serial number           : CAT1115NHDY
Version ID                     : V05
Switch 05
Base ethernet MAC Address       : 00:1B:90:6B:C5:00
Motherboard serial number       : CAT111550Z3
Power supply serial number     : DTH111210KC
System serial number           : CAT1115RHBS
Version ID                     : V05
Switch 06
Base ethernet MAC Address       : 00:1B:90:6B:7E:80
Motherboard serial number       : CAT1115510K
Power supply serial number     : DTH111210UV
System serial number           : CAT1115NHK6
Version ID                     : V05
Switch 07
Switch Uptime                   : 3 days, 21 hours, 9 minutes
Base ethernet MAC Address       : 00:1B:90:6B:54:00
Motherboard serial number       : CAT111550XT
Power supply serial number     : DTH111210J5
System serial number           : CAT1115NHG9
Version ID                     : V05
Switch 09
Base ethernet MAC Address       : 00:1B:90:6B:B4:80
Motherboard serial number       : CAT11155119
Power supply serial number     : DTH111210SL
System serial number           : CAT1115RHAL
Version ID                      : V05
Configuration register is 0xF
Sh switch detail:
                                               Current
Switch# Role     Mac Address     Priority     State
1       Member   001b.0dbf.1e00     15       Ready
2       Member   0018.baf2.f000     10       Ready
3       Member   001b.906b.7400     1         Ready
4       Member   001b.906b.9c00     1         Ready
5       Member   001b.906b.c500     1         Ready
6       Member   001b.906b.7e80     1         Ready
7      Member   001b.906b.5400     1         Ready
*8       Master   001a.e396.3900     1         Ready
9       Member   001b.906b.b480     1         Ready
         Stack Port Status             Neighbors
Switch# Port 1     Port 2           Port 1   Port 2
1       Ok         Ok               9       2
2       Ok         Ok               1       3
3       Ok         Ok               2       4
4       Ok         Ok               3       5
5       Ok         Ok               4       6
6       Ok         Ok               5       7
7       Ok         Ok               6       8
8       Ok         Ok               7       9
9       Ok         Ok               8       1
Dir flash1:
Directory of flash1:/
   2 -rwx     7205024 Feb 28 1993 21:18:10 -05:00 c3750-ipbasek9-mz.122-25.SEE2.bin
   3 -rwx         616 Dec 11 2011 12:13:29 -05:00 vlan.dat
   5 drwx         128 Feb 28 1993 21:15:35 -05:00 c3750-ipbase-mz.122-35.SE5
   6 -rwx       38838 Aug 30 2011 13:42:36 -04:00 config.text
509 -rwx         46 Aug 30 2011 13:42:37 -04:00 private-config.text
Dir flash2:
   2 -rwx     7205024 Feb 28 1993 21:24:53 -05:00 c3750-ipbasek9-mz.122-25.SEE2.bin
   3 -rwx         46 Aug 30 2011 13:42:38 -04:00 private-config.text
   4 -rwx       38838 Aug 30 2011 13:42:38 -04:00 config.text
   5 drwx         192 Feb 28 1993 19:08:17 -05:00 c3750-ipbase-mz.122-25.SEB4
363 -rwx         616 Dec 11 2011 12:13:29 -05:00 vlan.dat
Dir flash3:
Directory of flash3:/
   2 -rwx       38838 Aug 30 2011 13:42:37 -04:00 config.text
   3 -rwx         46 Aug 30 2011 13:42:37 -04:00 private-config.text
   4 -rwx         616 Dec 11 2011 12:13:18 -05:00 vlan.dat
   5 drwx         192 Feb 28 1993 20:56:02 -05:00 c3750-ipbasek9-mz.122-25.SEE2
Dir flash4:
Directory of flash4:/
   2 -rwx         46 Aug 30 2011 13:42:37 -04:00 private-config.text
   3 -rwx         616 Dec 11 2011 12:13:47 -05:00 vlan.dat
   4 -rwx       38838 Aug 30 2011 13:42:37 -04:00 config.text
458 drwx         192 Feb 28 1993 20:59:57 -05:00 c3750-ipbasek9-mz.122-25.SEE2
Dir flash5:
   Directory of flash5:/
   4 -rwx         616 Dec 11 2011 12:13:41 -05:00 vlan.dat
   5 drwx         192 Feb 28 1993 21:04:20 -05:00 c3750-ipbasek9-mz.122-25.SEE2
Dir flash6:
Directory of flash6:/
   4 -rwx         616 Dec 11 2011 12:13:35 -05:00 vlan.dat
   5 drwx         192 Feb 28 1993 21:08:38 -05:00 c3750-ipbasek9-mz.122-25.SEE2
Dir flash7:
XXXXmstack#dir flash7:
% Incomplete command.
Dir flash8:
Directory of flash:/
   3 -rwx         616 Feb 28 1993 19:01:43 -05:00 vlan.dat
   5 drwx         192 Feb 28 1993 21:17:16 -05:00 c3750-ipbasek9-mz.122-25.SEE2
458 -rwx       38838 Aug 30 2011 13:42:37 -04:00 config.text
Dir of flash9:
XXXXmstack#dir flash9:
Sh log:
The show log buffer is long since been overwritten:
Log Buffer (4096 bytes):
DOWN: Line protocol on Interface FastEthernet9/0/10, changed state to down
Dec 15 06:31:33: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet5/0/9, changed state to down
Dec 15 06:31:34: %LINK-3-UPDOWN: Interface FastEthernet9/0/12, changed state to up
Dec 15 06:31:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet9/0/13, changed state to up
Dec 15 06:31:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet9/0/10, changed state to up
Dec 15 06:31:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet5/0/9, changed state to up
Dec 15 06:31:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet9/0/12, changed state to up
Dec 15 06:31:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet5/0/9, changed state to down
Dec 15 06:31:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet5/0/9, changed state to up
Dec 15 07:28:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet6/0/13, changed state to down
Dec 15 07:28:50: %LINK-3-UPDOWN: Interface FastEthernet6/0/13, changed state to down
Dec 15 07:28:53: %LINK-3-UPDOWN: Interface FastEthernet6/0/13, changed state to up
Dec 15 07:28:54: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet6/0/13, changed state to up
Dec 15 07:29:14: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet6/0/13, changed state to down
Dec 15 07:29:16: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet6/0/13, changed state to up
Dec 15 07:29:29: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet6/0/13, changed state to down
Dec 15 07:29:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet6/0/13, changed state to up
Dec 15 07:29:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet6/0/13, changed state to down
Dec 15 07:29:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet6/0/13, changed state to up
Dec 15 07:32:22: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet7/0/20, changed state to down
Dec 15 07:32:23: %LINK-3-UPDOWN: Interface FastEthernet7/0/20, changed state to down
Dec 15 07:32:26: %LINK-3-UPDOWN: Interface FastEthernet7/0/20, changed state to up
Dec 15 07:32:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet7/0/20, changed state to up
Dec 15 07:32:33: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet7/0/20, changed state to down
Dec 15 07:32:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet7/0/20, changed state to up
Dec 15 07:32:48: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet7/0/20, changed state to down
Dec 15 07:32:50: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet7/0/20, changed state to up
Dec 15 07:32:57: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet7/0/20, changed state to down
Dec 15 07:32:59: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet7/0/20, changed state to up
Dec 15 08:45:33: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet9/0/8, changed state to down
Dec 15 08:45:34: %LINK-3-UPDOWN: Interface FastEthernet9/0/8, changed state to down
Dec 15 08:45:37: %LINK-3-UPDOWN: Interface FastEthernet9/0/8, changed state to up
Dec 15 08:45:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet9/0/8, changed state to up
Dec 15 08:45:39: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet9/0/8, changed state to down
Dec 15 08:45:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet9/0/8, changed state to up
Dec 15 08:45:54: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet9/0/8, changed state to down
Dec 15 08:45:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet9/0/8, changed state to up
Dec 15 08:46:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet9/0/8, changed state to down
Dec 15 08:46:06: %LINK-3-UPDOWN: Interface FastEthernet9/0/8, changed state to down
Dec 15 08:46:09: %LINK-3-UPDOWN: Interface FastEthernet9/0/8, changed state to up
Dec 15 08:46:10: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet9/0/8, changed state to up
Errr ... You have NINE (9) switch members in a stack????   Gee whiz!
1.  The "sh version" has shown that the entire stack rebooted due to power:  System returned to ROM by power-on
This could mean that your power source may have been hit with a power "spike" or the power board(s) where the stack is connected to is faulty.  Are the stack members connected to a single power board or power source?
2.  Regarding switch member 7 and 9, can you console into them and do the command "dir flash7:" and "dir flash9:" please?  I am interested to know if there are any crashinfo file(s)/directory.
3.  Wow.  That's an OLD IOS.  Can you try to upgrade it to something more recent?  Because your entire switch stack members have only 16mb of flash, the highest IOS you can go to is the 12.2(55)SE and later.  12.2(58) or 15.0(1)SE aren't supported.  IF you are going to the 12.2(55)SE-range, choose the 12.2(55)SE4 as this sub-version is more mature.
4.  You may need to reconsider "breaking" your stack.  When dealing with 3750/3750G/3750E/3750X, my rule of thumb for the amount of stack members in a stack should not exceed 6.  If you go 7 and more, some commands will cause the switch to "lag" and you'll think your switch stack has crashed.  If you don't believe me, I've got a number of soiled pants to show you.
leo......
Did I say thank you for your response?
The switches are not close by. We are attempting to gather the information you suggested but must wait for a tech to visit the site in order to retrieve information via console.
We have also taken to heart the suggestion of breaking the stacks up. More information to follow regarding that.
Mike
Thanks Mike.  Looking forward to the result of the last two switches and the inspection of the power board.
