Can I use different local AS# for each VRF?
frank
How can I use different local AS# for each VRF as we are trying to convert a Juniper MPLS network to use Cisco but their current Juniper routers has different local AS# per VRF and don't know if we can do that for IOS?
Example:
router bgp 2
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf VPN1
neighbor 1.1.1.1 remote-as 3
Can't find a command to specify the local AS# under "address-family ipv4 vrf VPN1"?
frank
Never mind... Found the answer and I will use the local-as when peering with the PE routers.
The local-as can only be used for EBGP peering but not IBGP.
Does anyone know how I can do the samething for IBGP peering?
I think you can only use eBGP in an address-family.
