can i use vpn services on my cisco 1841 router with 12.4 ios?
vasanth77
hi,
  we are using 1841 router with below version.can anybody tell this configuration and ios support for creating VPN to other router?
Router#show version
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SO
FTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 25-Oct-05 17:10 by evmiller
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Router uptime is 1 hour, 31 minutes
System image file is "flash:c1841-ipbase-mz.124-1c.bin"
Cisco 1841 (revision 6.0) with 114688K/16384K bytes of memory.
Processor board ID FHK10411A72
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
No, you need an "Advanced Security" image for VPNs. And (in reference to your other post), if you want to use IOS 15.1(4), you not only have to upgrade the CF-card, but also the RAM to 192 MB.
With your RAM/CF you could go up to 12.4(25g).
