Can IP SLA inject/interact with Policy based Routing?
bjames
Level 5
Level 5
I am looking at using both IP SLA (rtr) and policy-based routing to send some traffic (smtp let's say) over a VPN link and all other traffic over the WAN. In the event the VPN tunnel goes down, I wish all traffic to go ver the WAN link, and as well, if the WAN link goes down, I want all traffic to go over the VPN link, silly eh!
I was thinking of using both IP SLA and Policy mapping, but I wanted to know if IP SLA could inject the next-hop into the policy-map statments?
Thanks in advance,
Bob
johansens
Level 4
Level 4
It's called "Policy Based Routing with the Multiple tracking options Feature" and came in 12.3(4)T. I wrote this example with 12.4 in mind:
ip sla monitor 10
type echo protocol ipIcmpEcho 10.10.10.2
ip sla monitor 20
type echo protocol ipIcmpEcho 10.10.20.2
ip sla monitor schedule 10 life forever start-time now
ip sla monitor schedule 20 life forever start-time now
track 10 rtr 10 reachability
track 20 rtr 20 reachability
interface Tunnel0
description VPN-tunnel to SMTP server
ip address 10.10.10.1 255.255.255.0
interface Serial0
description WAN
ip address 10.10.20.1 255.255.255.0
interface Ethernet0
description LAN
ip policy route-map PBR
ip route 0.0.0.0 0.0.0.0 10.10.20.2
ip access-list extended WAN-acl
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended VPN-acl
permit tcp 192.168.1.0 0.0.0.255 any eq smtp
route-map PBR permit 10
match ip address VPN-acl
set ip next-hop verify-availability 10.10.10.2 10 track 10
set ip next-hop verify-availability 10.10.20.2 20 track 20
set default interface Null0
route-map PBR permit 20
match ip address WAN-acl
set ip next-hop verify-availability 10.10.20.2 10 track 20
set ip next-hop verify-availability 10.10.10.2 20 track 10
route-map PBR permit 30
Check this link for more info on this feature:
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a0080211f5c.shtml
Here's the doc from 12.4 (they changed it from RTR to IP SLA monitor):
http://www.cisco.com/en/US/partner/products/ps6350/products_configuration_guide_chapter09186a0080457bcc.html
