Can it be done on Cisco router?
thnguyen2011
Hi All,
Can this scenario be done one the cisco 877 router?
I have VPN Ipsec up and runing on both site. How can to configure the port forwarding to the remote server over the tunnel?
http://www.sirkit.ca/wiki/2012/03/port-forwarding-through-an-ipsec-tunnel-to-a-remote-serverpc-with-fortinet/
Thai
16 Replies 16
do you have yahoo id? add me, im endoch6@yahoo.com so that we can talk online
thnguyen2011
Hi All,
As per Karsten advise and the help of handoko. Here is my configure but it still does not work.
interface Loopback100
description Loopback for testing hairpinning
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer0
description ---ADSL Detail---
ip address negotiated
ip mtu 1460
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1420
ip policy route-map hairpin
dialer pool 1
dialer-group 1
ppp chap hostname myusername@isp.com
ppp chap password mypassword
crypto map SDM_CMAP_1
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 192.168.0.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 100 permit ip 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 remark CCP_ACL Category=3
access-list 101 remark IPSec Rule
access-list 101 deny   ip 192.168.0.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
access-list 115 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 115 permit ip 192.168.3.0 0.0.0.255 192.168.2.0 0.0.0.255
route-map SDM_RMAP_1 permit 1
match ip address NAT
route-map hairpin permit 115
match ip address 115 set dialer0
ip dns server
ip nat inside source static tcp 192.168.0.51 3389 interface Dialer0 3389
ip nat inside source static tcp 192.168.2.99 80 interface Dialer0 8000
ip nat inside source static tcp 192.168.2.99 9100 interface Dialer0 9100
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
Here is some output
sh ip nat transtraltions
Laverton#sh ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
tcp 120.146.xxx.xxx:3389 192.168.0.51:3389 120.146.xxx.xxx:50712 120.146.xxx.xxx:50712
tcp 120.146.xxx.xxx:3389 192.168.0.51:3389 120.146.xxx.xxx:50723 120.146.xxx.xxx:50723
tcp 120.146.xxx.xxx:3389 192.168.0.51:3389 120.146.xxx.xxx:50724 120.146.xxx.xxx:50724
tcp 120.146.xxx.xxx:3389 192.168.0.51:3389 ---                ---
tcp 120.146.xxx.xxx:8000 192.168.2.99:80   120.146.xxx.xxx:50718 120.146.xxx.xxx:50718
tcp 120.146.xxx.xxx:8000 192.168.2.99:80   120.146.xxx.xxx:50719 120.146.xxx.xxx:50719
tcp 120.146.xxx.xxx:8000 192.168.2.99:80   120.146.xxx.xxx:50725 120.146.xxx.xxx:50725
tcp 120.146.xxx.xxx:8000 192.168.2.99:80   ---                ---
tcp 120.146.xxx.xxx:9100 192.168.2.99:9100 120.146.xxx.xxx:50722 120.146.xxx.xxx:50722
tcp 120.146.xxx.xxx:9100 192.168.2.99:9100 ---                ---
RDP is working but http and printer port are not working.
sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
120.146.xxx.xxx  123.209.xxx.xxx  QM_IDLE           2001 ACTIVE
IPv6 Crypto ISAKMP SA
Am i missing something?
