Can PING from any Public/Global IP but cannot PING from any Private IP addresses
Japayuki69
Hi Guys,
I am desperate, I think this is just a simple problem but my knowledge to CISCO is not that really deep.
Please help!
(Note: All Actual IP info are Sanitized)
Our ISP has provided our Company the following Information.
WAN-out AAA.BBB.CCC.72/29  IP8 Numbered
WAN-in AAA.BBB.DDD.192/26  IP64
Assigned ISP router IP is AAA.BBB.CCC.73
Assigned Client Router IP is AAA.BBB.CCC.74/29
Used Router is Cisco 1921 with 2 Gigabit port.
Port Gi0/0 @ AAA.BBB.CCC.74 255.255.255.248
Port Gi0/1 @ AAA.BBB.DDD.193 255.255.255.192
Gi0/1 is connected to a Cisco Switch which has other devices connected to it such as web, sub-routers, etc...
Sub-Router IP @ AAA.BBB.DDD.205
Web-Server IP @ AAA.BBB.DDD.200
Etc...
Problem:
I can ping the specific AAA.BBB.DDD.193 assigned to the Router port Gi0/1 from any Private IP or Public IP address.
The rest of the IP addresses AAA.BBB.DDD.192/26 can be ping directly from any Public IP
but it cannot be PING from a Private IP address.
It sounds like more on NATting on the Router config, Please help!
I have included the SANITIZED config For Your Reference.
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ISP_STATIC_@_100MBPS_INTERNET
ip address AAA.BBB.CCC.74 255.255.255.248
ip access-group FILTER_FROM_INTERNET in
ip access-group FILTER_INTERNET in
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description WAN_IP64_AAA_BBB_DDD_192/26
ip address AAA.BBB.DDD.193 255.255.255.192
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map 01_ISP_NAT interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 AAA.BBB.CCC.73
ip access-list extended FILTER_INTERNET
permit ip AAA.BBB.DDD.192 0.0.0.63 any
ip access-list extended FILTER_VTY_ACCESS
permit ip AAB.BBA.ADA.88 0.0.0.7 any
ip access-list extended ISP_NAT_ACL
no cdp run
route-map 01_ISP_NAT permit 10
match ip address ISP_NAT_ACL
control-plane
alias exec s show ip int brief
alias exec sr show running-config
alias exec sacl show access-list
banner motd ^C
/*/*/*/                        DO NOT LOGIN                    */*/*/*/
^C
line con 0
exec-timeout 500 0
logging synchronous
login local
length 0
line aux 0
exec-timeout 5 0
logging synchronous
login local
length 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class FILTER_VTY_ACCESS in
exec-timeout 20 0
logging synchronous
login local
length 0
transport input ssh
line vty 5 1370
exec-timeout 5 0
logging synchronous
login local
length 0
transport input ssh
scheduler allocate 20000 1000
end
Thank you in advance.
John Blakley
On g0/0, you reference an acl that doesn't exist (or at least in the config you posted it doesn't). You should remove this for testing purposes. Your nat configuration also references the inside interface instead of the outside interface to nat out as, so change that to the following:
ip nat inside source route-map 01_ISP_NAT interface GigabitEthernet0/0 overload
HTH,
John
HTH, John *** Please rate all useful posts ***
6 Replies 6
John Blakley
HTH,
John
Hi John,
Thank you for the Swift Reply.
My bad and sorry for the confusions.
I sanitized the original config too much and I forgot to edit the "access-group" for gi0/0.
The original message is now modified.
Tried already both
ip nat outside source... (using this will disconnects other devices from the internet)
ip nat inside source... (thisconnects other devices but still no PING can be achieved)
Any other suggestion?
Thank you very much.
Erase the route-map and match the ACL directly.
Hardcode the speed and the duplex mode...
check also the ACL you wrote down... there is a duplicate...
Alessio
Hi Alessio,
Thank you for the reply, tried it as per advise but it seems this is not working.
The duplicated ACL were actually part of illustration and should not confused with, it has a lot more IP but was just sanitized.
Hello John,
I reviewed back your suggestions and found the answer.
Gi0/1 interface was just NAT OUT.
ip nat inside
ip nat outside
duplex auto
speed auto
Glad to hear! Thanks for the rating and closing the question out!
