Can ping internet from console but not from pc
andri.vork
We let cisco professional to configure 1941w router with EHWIC-3G card. So the Gig 0/0 and wlan clients could communicate the internet over 3G.
So we bought another 1941w and copied the config over to new one. Can ping from console but not from client pc.
The only differents between old and new is "ip source-nat" line. New router just don't save it to running-conf. No errors also.
Router#show run
Building configuration...
Current configuration : 3238 bytes
! No configuration change since last restart
version 15.2
hostname Router
boot-start-marker
boot-end-marker
logging buffered 16000
enable secret 5 xxxxxxxxxxxxxxxxxxxxxx.
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip dhcp excluded-address 10.10.1.1 10.10.1.31
ip dhcp pool sise
network 10.10.1.0 255.255.255.0
default-router 10.10.1.1
dns-server 194.204.0.1
ip dhcp pool wifi
network 10.10.2.0 255.255.255.0
default-router 10.10.2.1
ip cef
chat-script gsm0 "" "ATDT*99*3#" TIMEOUT 60 "CONNECT"
license udi pid CISCO1941W-E/K9 sn xxxxxxxxxxxxxx
hw-module ism 0
username admin privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxx
controller Cellular 0/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.10.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 10.10.11.1 255.255.255.0
ip nat inside
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Cellular0/0/0
ip address negotiated
ip nat outside
encapsulation ppp
dialer in-band
dialer string gsm0
dialer-group 1
async mode interactive
ppp chap hostname elisa
ppp chap password 0 elisa
ppp ipcp dns request
interface Cellular0/0/1
no ip address
encapsulation ppp
interface Vlan1
ip address 10.10.3.1 255.255.255.0
ip nat inside
interface Vlan2
description WiFi
ip address 10.10.2.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list natlist interface Cellular0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
ip access-list extended natlist
permit ip 10.10.1.0 0.0.0.255 any
permit ip 10.10.2.0 0.0.0.255 any
permit ip 10.10.3.0 0.0.0.255 any
access-list 1 permit any
dialer-list 1 protocol ip list 1
control-plane
line con 0
line aux 0
line 2
script dialer gsm0
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0
exec-timeout 0 0
script dialer gsm0
modem InOut
no exec
transport input all
transport output all
rxspeed 7200000
txspeed 5760000
line 0/0/1
no exec
rxspeed 7200000
txspeed 5760000
line 67
no exec
transport input all
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Please help.
Thank You
7 Replies 7
andri.vork
I noticed one difference.
Old router config was starting with line "version 15.1"
But now is 15.2.
Should i downgrade to 15.1?
Andri,
don't downgrade your router unless strange IOS behaviour and find out why the ip source nat command line does not come up in your config. With no NAT all the private IP (like your host) won't go in anywhere while the router possibly is chosing a public IP to encapsulate the ongoing packet. try this:
ping Internet_IP source 10.10.11.1
you should not get any echo-reply also if you do this from console. if i am right you definitely need to write down the line code for NAT on the new 1941w.
Alessio
I'm not an expert - thats why i cant write new code.
So far i have progress. Downgraded to 15.1 and the nat is working now.
But there is new problem. Wireless clients cant get their ip from dhcp.
Here is AP config:
version 12.4
no service pad
service password-encryption
hostname ap
no aaa new-model
no ip domain lookup
dot11 syslog
dot11 ssid kbv
   vlan 2
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 xxxxxxxxxxxxxxxxxxx
username tester privilege 15 secret 5 xxxxxxxxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 mode ciphers aes-ccm tkip
broadcast-key vlan 2 change 3600
ssid kbv
antenna gain 0
mbssid
station-role root
interface Dot11Radio0.1
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid kbv
antenna gain 0
no dfs band block
mbssid
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface Dot11Radio1.2
no ip route-cache
bridge-group 2
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 10.10.3.2 255.255.255.0
no ip route-cache
ip default-gateway 10.10.3.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Hi Andri,
you did not write any dhcp pool so you can't provide IPs to your wireless clients. If the dhcp server is not the router but a server in another point of the network possibly you want to implemen on the vlan of your clients the ip helper-address command to point to the dhcp server ip address.
Alessio
PS: very few in this forum are real experts (me EXcluded)
On the router side there are dhcp pool for wlan. On the first router it did work.
ip dhcp pool wifi
Set the excluded ip addresses in the pool
Alessio
Added it, but still nothing.
Now it looks following:
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.2.1 10.10.2.31
ip dhcp pool sise
ip dhcp pool wifi
