Can same port interface be assign to different VLANS?
javaboy
is it possible to assign the same port interface to different VLANs?
Can someone explain the below VLAN?
VLAN Name Status Ports
1 default active Gi0/25, Gi0/26, Gi0/27, Gi0/28
10 CENTECH active
20 THRREA active
30 Group2 active
40 voice active
50 VLAN0050 active Gi0/1, Gi0/2, Gi0/3, Gi0/4
Gi0/5, Gi0/6, Gi0/7, Gi0/8
Gi0/9, Gi0/10, Gi0/11, Gi0/12
Gi0/13, Gi0/14, Gi0/15, Gi0/16
Gi0/17, Gi0/18, Gi0/19, Gi0/20
Gi0/21, Gi0/22, Gi0/23, Gi0/24
136 VLAN0136 active Gi0/1, Gi0/2, Gi0/3, Gi0/4
5 Replies 5
This can happened if the port is config with one data vlan and one voice vlan.
Kindly check the VLAN information. VLAN 50 and Vlan 136 have been assigned with the same port int.
Yes I already see and reply
You can config two vlan under access port
One data vlan
Other is voice vlan
So it normal.
 Can you show the command "show run config
  Gi0/1"
Joseph W. Doherty
As @MHM Cisco World already noted, for an access port, it can be done on a switch that support a voice VLAN in addition to the number port VLAN assignment.
I believe you might see the same results, i.e. multiple VLANs assigned to the same port, if port is a trunk port too.
As @Flavio Miranda requested, showing the concurrent running config would confirm our suspicions.
