Static Routing - IP SLA Track for Tunnel using Front Door VRF
SoloRocky
I have an interesting problem with IP SLA tracking. Here is the scenario:
- Two static routes, primary and default
ip route vrf MAIN 0.0.0.0 0.0.0.0 10.10.10.2
ip route vrf MAIN 172.12.12.0 255.255.255.248 tunnel50
- Tunnel 50
Int Tunnel50
vrf forwarding MAIN
ip add 192.168.1.1 255.255.255.252
tunnel source loopback7
ip tcp adjust-mss 1360
tunnel destination 10.20.20.2
tunnel vrf WAN
- Adding IP SLA for primary path using Tunnel 50
ip sla 2023
icmp-echo 10.20.20.2 source-int vlan 201
freq 5
vrf WAN
track 2023 ip sla 2023
- Adding tracking to static route for tunnel
ip route vrf MAIN 172.12.12.0 255.255.255.248 tunnel50 track 2023
- The Problem
Tunnel VRF is MAIN and so is the static route to the tunnel. However, ip sla uses VRF WAN. I haven't found any documentation to show this will work
This is on ASR 1001x with IOS-XE and I don't have a testbed. I can think of using route leaking between VRFs MAIN and WAN but want to if  anyone implemented this.
Hello
Your ipsla is polling an address in a different VRF than the static route you wish to track so it will not work your need to track within the same VRF
Kind Regards
Paul
Anil-Verma-1
This is chicken and egg
Tunnel50 is in vrf MAIN
IP SLA has to use vrf WAN and source-int also in vrf WAN
Try this:
- Use vrf MAIN for ip sla - this is needed to ensure track 2023 can use ip sla 2023
- route leak 10.20.20.2 and vlan 201 from vrf WAN to vrf MAIN
@SoloRocky  please confirm if this issue solve or not
thanks
MHM
