Can't access internet with C1101-4P Router
acet
My VLAN users are unable to access Internet. I have tried different access lists and can't figure out the problem. Can someone tell me what is missing here?
Thank you.
interface GigabitEthernet0/0/0
description Connection to Internet
ip address 1.2.3.4 255.255.255.0
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface Vlan1
ip address 172.16.1.1 255.255.255.0
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/0
ip http client secure-trustpoint SLA-TrustPoint
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 1.2.3.5
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
add the lines marked in bold to your configuration:
--> ip nat outside
negotiation auto
interface Vlan1
--> ip nat inside
ip http server
--> ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
--> access-list 1 permit 172.16.1.0 0.0.0.255
5 Replies 5
--> ip nat outside
negotiation auto
interface Vlan1
--> ip nat inside
ip http server
Thank You Georg.
ip nat outside
negotiation auto
interface Vlan1
ip nat inside
ip http server
ip route 0.0.0.0 0.0.0.0 1.2.3.4
ip access-list standard 1
10 permit 172.16.1.0 0.0.0.255
Update:
I removed this line:
because it was working sporadically probably due to this error:
%Default route without gateway, if not a point-to-point interface, may impact performance
if you know the next hop IP address, and if that is a static address, it is indeed better to use this address. The 'error' message is not really an error message, it just tells you that the router has to ARP for the next hop, which can add a delay to your connection. In reality, that delay is negligible.
Hello
You are using private non public routable addressing as such your clients will not be able to reach the internet, to accomplish this you will require a routing device (rtr or high end switch) that can perform Network/Port Address Translation ( NAT/PAT)
Also suggest you defined a fully specified static routes when the need arises. (nexthop interface and ip address.
Example
no ip route 0.0.0.0 0.0.0.0 1.2.3.5
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 1.2.3.5
Kind Regards
Paul
