can't access the network via cisco router 2611xm config with a pppoe
Hello guys,
I'm Ben, I came to you guys with hope of helping me with a sort of problem that probably no one had.
So let's dive in the problem.
I have a pppoe connection from my ISP and I set up it on my cisco router with the account password and other things I need it, utill now everything was good. The problem stats after I set up on my laptop a ip, net mask, gateway, dns. I can't browse it on the net but I can ping any ip or domain (from the router and just ips form laptop), with my DNS that was provide it to me from my ISP but with an open dns llike 8.8.8.8 and 8.8.4.4 I can go on the internet.
summary: with my dns from isp can go on internet just ping, but with open dns from google I can
Can someone help me I try to find a solution for days.
Thank you in advance
I have a cisco router 2611xm with following config
Current configuration : 2177 bytes
version 12.4
service password-encryption
hostname R1-ALFA
boot-start-marker
boot-end-marker
security passwords min-length 10
enable secret 5 ***********************
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip domain name domain.ro
ip name-server 213.156.124.1
ip name-server 193.231.255.1
login block-for 180 attempts 3 within 180
username ******* password 7 **********
archive
 log config
  hidekeys
interface FastEthernet0/0
 description The interface that talk with ISP
 no ip address
 duplex auto
 ip nat outside
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 12
 no cdp enable
interface FastEthernet0/1
 description The interface that let you to play inside
 ip address 172.16.30.161 255.255.255.240
 ip nat inside
 ip virtual-reassembly
 no ip mroute-cache
 duplex auto
 speed auto
 no cdp enable
 no mop enabled
interface Dialer12
 ip address negotiated
 no ip redirects
 no ip unreachables
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 no ip mroute-cache
 dialer pool 12
 dialer idle-timeout 0
 dialer persistent
 dialer-group 12
 no cdp enable
 ppp authentication pap callin
 ppp pap sent-username ********** password 7 ***********
 ppp ipcp dns request
 ppp ipcp route default
 ppp ipcp address accept
ip forward-protocol nd
ip http server
no ip http secure-server
ip dns server
ip nat inside source list 15 interface Dialer12 overload
access-list 15 permit 172.16.30.160 0.0.0.15
dialer-list 12 protocol ip permit
no cdp run
control-plane
banner motd ^CIf you're not the Admin get out!!^C
line con 0
 exec-timeout 180 0
 login local
line aux 0
line vty 0 4
 login local
line vty 5 15
 login local
end
Hello
These two commands below should help any internal client dns request originating from this router to service dns.
ppp ipcp dns request  < -- obtain public dns from ISP
ip dns server < acts like a proxy dns server for client
What you are doing at the moment is manually bypassing using your own ISPs dns server and that's why it works using google DNS, For it to work using your own rtrs ISPs DNS, set the clients dns server to point to the router, In your case the client dns server will be 172.16.30.161 then test again.
Edited- if you are going to create a dhcp pool for you clients as suggest by @Georg Pauwen  set the dns server to your own router, Would also say you don't need to specify a static default route as you are receiving one from the ISP already.
> ip dhcp pool LAN
--> network 172.16.30.160 255.255.255.240
--> default-router 172.16.30.161
--> dns-server 172.16.30.161
Kind Regards
Paul
7 Replies 7
first of all, you have no default route. Add this to your configuration:
ip route 0.0.0.0 0.0.0.0 Dialer12
If this doesn't help, which DNS servers are you using ? The easiest would be to just use the router as DHCP server, with the configuration changes maked in bold:
version 12.4
hostname R1-ALFA
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
--> no ip name-server 213.156.124.1
--> no ip name-server 193.231.255.1
--> ip dhcp excluded-address 172.16.30.161
--> ip dhcp pool LAN
--> dns-server 8.8.8.8 8.8.4.4
archive
log config
hidekeys
no ip address
duplex auto
ip nat outside
speed auto
no cdp enable
ip nat inside
no ip mroute-cache
duplex auto
speed auto
no cdp enable
no mop enabled
interface Dialer12
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 12
dialer persistent
dialer-group 12
no cdp enable
ip http server
ip dns server
--> ip route 0.0.0.0 0.0.0.0 Dialer 12
no cdp run
control-plane
line con 0
exec-timeout 180 0
login local
line aux 0
line vty 0 4
login local
line vty 5 15
login local
end
Hello @Georg Pauwen
adding a static default isn't require as the router accepting the ISPs -  ppp ipcp route default
Kind Regards
Paul
ciao,
I tried what you said, without result, but what said @paul driver it work
Thank you for you time and help
Hello
> ip dhcp pool LAN
Kind Regards
Paul
ola,
I set the dns from dhcp to my default-gateway and now is works fine.
Now I have other question "why now is working :))))))"
With the config
ip dhcp pool IntraNet-LAN
lease infinite
is ok
Hello
i have already explained why,
Kind Regards
Paul
