Can't apply service policy output (Tunnel)
Ivan_IFZ
Hi all,
I need to configure this command "service-policy output X" to different IPSEC tunnels. I can apply it to all tunnels, no errors. But if I do a "show policy-map interface", I see only one tunnel
Router: cisco ASR1002-X (2RU-X)
Config:
rtcore(config)#int tu2
rtcore(config-if)#service-policy output TRAFFIC_CC
rtcore(config)#int tu3
rtcore#sh run int tun2
interface Tunnel2
description TO-Branch
ip unnumbered Loopback0
ip flow monitor FlowMonitor1 input
ip flow monitor FlowMonitor1 output
ip summary-address eigrp 1 0.0.0.0 0.0.0.0
delay 6000
tunnel source Loopback0
tunnel destination 10.10.0.2
tunnel protection ipsec profile tunel
end
rtcore#sh run int tun3
interface Tunnel3
description To-Branch_2
delay 4000
tunnel destination 10.20.0.2
end
rtcore#sh policy-map interface
Tunnel2
Service-policy output: TRAFFIC_CC
Class-map: class-default (match-any)
386553 packets, 32470605 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: any
Queueing
queue limit 362 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 52/7688
shape (average) cir 87000000, bc 348000, be 348000
target shape rate 87000000
Service-policy : TRAFFIC_SCCM
Class-map: LIMITSCCM (match-all)
0 packets, 0 bytes
Match: access-group name SCCM
Queueing
queue limit 64 packets
(pkts output/bytes output) 0/0
shape (average) cir 10000000, bc 40000, be 40000
target shape rate 10000000
Match: any
Do you have any idea why I can't see this configuration applied to all tunnels? I couldn´t find anything in logs
Thanks in advance!
0 Replies 0
