Can't Auto config end devices using IPv6
Boda
I built a network using IPv4, used RIPv2 as routing protocol and it worked well. I then tried to also add IPv6 to the network. I did the IPv6 unicast-routing and added the addresses to all the connections. However, when I try to auto configure the end devices using the GUI, the fields turn blank and never show an IPv6 address. I tried hovering over the devices and it showed an IPv6. So then I tried to ping the devices using the IPv6 addresses but it said that the target was unreachable. I have attached my network and a picture of my IPv6 schema. Any help would be much appreciated.
0 Replies 0
