can't change or remove netflow setting from an ASA 5520
Brent Rockburn
Level 2
Level 2
I've tried in the ADSM and I've tried the CLI and I can't remove or change these entries.
Any know what I'm doing wrong here?
fw-x-5520-1(config)# flow-export destination iSP2/Swift 10.xx.x.xx 2055
ERROR: flow-export: destination already exists
fw-x5520-1(config)# no flow
fw-x5520-1(config)# no flow-export en
fw-x-5520-1(config)# no flow-export enable
ERROR: This command is no longer supported. Flow-export actions under MPF need to be removed to stop exporting NetFlow events.
fw-x5520-1(config)#
14 Replies 14
try the no flow-export destination iSP2/Swift 10.xx.x.xx 2055
and then try to remove the no flow-export enable
Doesn't matter what order I do it in I get the same results.
how about this command:
no export destination ip-address port
no ip flow-export destination ip-address udp-port
sorry for the ASA try clear configure flow-export
fw-517-5520-1(config)# clear configure flow-export
ERROR: Some destinations may be in use. Remove references before attempting to delete
fw-517--5520-1(config)#
Still no worky!!
give the details of sh run | i flow-export
The error is showing destination in use because it value is yet to time out
try again the same command.
This appears when I do a sh run but not when I look through the config itself.
fw-517-5520-1# sh run | in flow
flow-export destination ISP2/Swift 10.66.x.x 2055
  flow-export event-type all destination 10.66.x.x
fw-517-5520-1#
Has this issue been resolved.  I'm having the same issue.  Thanks.
Doug
Remove the netflow configuration from the policy-map first (or just remove the class that has the netflow association from the policy-map), then you would be able to remove the netflow configuration.
Hope that helps.
Thanks for the reply.  Here is the config for policy-map. I tried to remove the policy map but got the error below.  What is the correct commands to remove flow-export?  Thanks.
policy-map global_policy
class class-default
  flow-export event-type all destination 10.59.1.53
AlzASA(config)# no policy-map global_policy
ERROR: policy-map global_policy is being used and hence cannot be removed.
Here is the steps:
no service-policy global_policy global
     no class class-default
It worked!!!  Thank you for your help.
Doug
raymundozuniga
Had same issue.
(config)# sh run flow-export
flow-export destination inside 192.168.xxx.xxx 512
flow-export template timeout-rate 1
flow-export delay flow-create 15
(config)# no class-map flow_export_class
ERROR: % class-map flow_export_class is being used
SOLUTION
I had to look at policy-map first
(config)## sh run policy-map
class flow_export_class
flow-export event-type all destination 192.168.xxx.xxx
So I did
(config)## policy-map global_policy
(config-pmap)# no class flow_export_class
(config-pmap)# exit
(config)## sh run class-map
match access-list flow_export_acl
(config)#no class-map flow_export_class
(config)# ---empty--- YESSS!!!!
I was clear of the netflow config and I cold move on !!!
smbusta
have you tried this > no class export-netflow-class or clear config class export-netflow-class
