Can't configure static routing among 3 routers
chocolichnk
I am trying to set up static routing among the devices here but failing for some reason. Please help me by providing the process to send a packet from one device to another, for example: PC2 to PC4?
2 Accepted Solutions
the IP addressing on your serial interfaces was mixed up. Attached the working file with static routes (saved in PT version 8.1, you need this latest version installed in order to open the file)>
in case you don't have version 8.1 installed, here are the working configs for the routers:
Star_City#sh run
Building configuration...
Current configuration : 832 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Star_City
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
ip address 192.168.32.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 192.168.30.2 255.255.255.0
clock rate 64000
interface Serial0/0/1
ip address 192.168.31.1 255.255.255.0
clock rate 64000
interface Vlan1
no ip address
shutdown
ip classless
ip route 192.168.34.0 255.255.255.0 192.168.31.2
ip route 192.168.33.0 255.255.255.0 192.168.30.1
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Metropolis#sh run
Current configuration : 815 bytes
version 12.4
hostname Metropolis
ip cef
no ipv6 cef
ip address 192.168.34.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 192.168.28.2 255.255.255.0
clock rate 64000
ip address 192.168.31.2 255.255.255.0
interface Vlan1
no ip address
shutdown
ip classless
ip route 192.168.32.0 255.255.255.0 192.168.31.1
ip route 192.168.33.0 255.255.255.0 192.168.28.1
line con 0
line aux 0
line vty 0 4
login
end
Coast_City#sh run
Current configuration : 797 bytes
version 12.4
hostname Coast_City
ip cef
no ipv6 cef
ip address 192.168.33.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 192.168.30.1 255.255.255.0
ip address 192.168.28.1 255.255.255.0
interface Vlan1
no ip address
shutdown
ip classless
ip route 192.168.32.0 255.255.255.0 192.168.30.2
ip route 192.168.34.0 255.255.255.0 192.168.28.2
line con 0
line aux 0
line vty 0 4
login
end
Star_City#
Star_City#sh run
version 12.4
hostname Star_City
ip cef
no ipv6 cef
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
clock rate 64000
clock rate 64000
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Metropolis#sh run
version 12.4
hostname Metropolis
ip cef
no ipv6 cef
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
clock rate 64000
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Coast_City#sh run
version 12.4
hostname Coast_City
ip cef
no ipv6 cef
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Star_City#
Hello, Thanks a lot for your help, it worked!
