can't get an IP @ from bridged dhcp
jackhunter
Hello I installed the CSR100v router in VMware workstation and I connect the first interface (g1) to the bridged of my WLAN network and when I configured this interface to get IP @ from DHCP it don't get i don't know why ???
check the DHCP Server side your config for router is OK
Hello
how is that rtr connected  is it within a vlan of an active dhcp scope
Kind Regards
Paul
my VM router is not in vlan and my adsl router also
Have you enabled promiscous mode on the vswitch?
