Can't Get Internet Connectivity on 3G router
martino-cisco
Hi All,
Please can I get some assistance with problems configuring a 3G router. APN, Username, Password and Authentication have been provided. I can't get an active profile to work still.
Profile 1 = INACTIVE
PDP Type = IPv4
Access Point Name (APN) = wap.vodafone.co.uk
Authentication = PAP
Username: wap, Password: wap
Running config is below:
Current configuration : 1972 bytes
! Last configuration change at 14:31:31 UTC Thu May 5 2016
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging buffered 12000
no aaa new-model
memory-size iomem 10
service-module wlan-ap 0 bootimage autonomous
ip source-route
ip cef
no ipv6 cef
chat-script gsm "" "atdt*98*1#" TIMEOUT 30 "CONNECT"
license udi pid CISCO881GW-GN-E-K9 sn FCZ1425C0JV
controller Cellular 0
interface FastEthernet0
switchport access vlan 10
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Cellular0
ip address negotiated
ip nat outside
no ip virtual-reassembly
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string gsm
dialer-group 1
async mode interactive
ppp chap hostname wap
ppp chap password 0 wap
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.60.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list INTERNET-ACCESS interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip access-list extended INTERNET-ACCESS
permit ip any any
control-plane
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line 3
script dialer gsm
modem InOut
no exec
transport input all
rxspeed 7200000
txspeed 5760000
line vty 0 4
login
transport input all
johnlloyd_13
Level 9
Level 9
hi,
could you try these commands?
no chat-script gsm "" "atdt*98*1#" TIMEOUT 30 "CONNECT"
chat-script gsm "" "AT!CALL" TIMEOUT 20 "OK"
interface Cellular0
 encapsulation slip
 no ppp chap hostname wap
 no ppp chap password 0 wap
 no async mode interactive
interface Vlan10
 ip nat inside
access-list 1 permit 192.168.60.0 0.0.0.255
no ip nat inside source list INTERNET-ACCESS interface Cellular0 overload
ip nat inside source list 1 interface Cellular0 overload
dialer-list 1 protocol ip permit
Hi John,
Thanks for your response. I finally cracked it using the Dialer0 interface. To be honest, I still can't tell when to use or not to use the Dialer0 over the Cellular0 interface.
See configs below...for anyone who may need this at some point.
interface Cellular0
no ip address
ip nat outside
encapsulation ppp
no ip route-cache cef
dialer in-band
dialer pool-member 1
dialer-group 1
interface Vlan1
no ip address
interface Vlan10
ip nat inside
interface Dialer0
ip nat outside
encapsulation ppp
no ip route-cache
dialer pool 1
dialer string gsm
dialer persistent
dialer-group 1
no cdp enable
no ip http server
ip dns server
ip nat inside source list INTERNET-ACCESS interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
permit ip any any
access-list 1 permit any
dialer-list 1 protocol ip list 1
