Can't login to privilege level 15 user after firmware upgrade
Dox2163
Before the upgrade, I was able to SSH into a level 15 user and it would land me directly to # without using enable.
After upgrading to from 16.3.8 to 16.9.4, my level 2 account can still SSH in but level 15 user account gets % login invalid. So I try going from level 2 and then enable, then it says % No password set. This is a cat 3850
Any help appreciated. I haven't had a chance to console yet.
2 Accepted Solutions
RicardoSN
Hello Dox2163,
According to Cisco's Release notes for 16.9.4 there are no new software features.
That's a long versions jump though... It's possible that in between versions 16.3.8 to 16.9.4 there was an update on some management configurations that could cause this.
Anyways, getting back to your issue. The "% login invalid" will prompt when the user or password typed are not configured on the Switch you're trying to access. Being that the case, it would depend on which authentication method you are using why is this happening, it may be a Tacacs+ or Radius server related issue or something else.
If you are using Local users the most probable scenario is that for some reason your level 15 user got lost in the limbo (deleted) and you most likely will have to perform a Password Recovery to re configure it.
Here is a procedure for Cisco Catalyst 3850.
https://www.rogerperkin.co.uk/cisco/switching/3850/password-recovery-cisco-catalyst-3850/
If you're not that near to the Switch to perform a Password Recovery locally, you could also try this procedure. (Only if the Switch has SNMP configured).
https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/15217-copy-configs-snmp.html
Good Luck!
-Ricardo S.N., Regards!
Thank you for everyone's help.
I was able to get in via console. I immediately checked the show run and all users were gone except the one level 2 user.
I recreated my users and was able to downgrade the firmware.
I was going to perform a password recovery as ricardoSN suggested if console didn't work. Can I accept multiple solutions?
13 Replies 13
Richard Burts
I am not clear whether the no password set error is generated when you attempt to login for your level 2 account or whether your login for level 2 is successful and the error is generated when you attempt to use the enable command. Can you clarify?
I hope your console access is successful when you try it. But I am concerned that it may have the same issue. If it is successful then please get a copy of the current running config and post it (after obscuring sensitive information such as passwords and public IP).
Rick
Rick
Login to level 2 is successful, the no password set error appears when I enter enable or enable 15.
RicardoSN
Hello Dox2163,
Good Luck!
Thanks for the update letting us know that your console access was successful and allowed you to identify and correct the problem. That is good to know.
Yes it is possible to accept more than one answer as a solution.
Rick
Rick
switch: boot
boot: attempting to boot from [flash:cat9k_iosxe.17.03.04.SPA.bin]
boot: reading file cat9k_iosxe.17.03.04.SPA.bin
switch:
switch:
switch: boot
Both links down, not waiting for other switches
Switch number is 1
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           Cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.3.4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Sat 03-Jul-21 01:55 by mcpre
This software version supports only Smart Licensing as the software licensing mechanism.
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
FIPS: Flash Key Check : Key Not Found, FIPS Mode Not Enabled
All TCP AO KDF Tests Pass
cisco C9300-48UXM (X86) processor with 1331366K/6147K bytes of memory.
Processor board ID FOC2225U0RE
2048K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
11264000K bytes of Flash at flash:.
Base Ethernet MAC Address          : 6c:6c:d3:d1:e9:00
Motherboard Assembly Number        : 73-17959-06
Motherboard Serial Number          : FOC222218PZ
Model Revision Number              : D0
Motherboard Revision Number        : A0
Model Number                       : C9300-48UXM
System Serial Number               : FOC2225U0RE
CLEI Code Number                   :
Press RETURN to get started!
######## KEY IS TO WAIT HERE TILL THE IOS IMAGE GETS LOADED TILL YOU GET THE BELOW SWITCH PROMPT #####
*Switch>en
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#copy start
Switch#copy startup-config runn
Switch#copy startup-config running-config
Washinton-SR-c9300#. ===>>.
Hello
Sounds like your exec authorization hasnt been appended correctly either at line level or using AAA
So are you using local authentication and if so is this with AAA or without?
Can you post you run configuration please
sh run | in username|aaa|line
Kind Regards
Paul
This is the result from above command. After the upgrade, it seems all my users were wiped out except the that one level 2 user.
no aaa new-model
username xxxxxxx privilege 2 secret 5 xxxxxxxxxxxxxxxxxx
line con 0
line aux 0
line vty 0 4
line vty 5 15
on a side note, and you might have already tried this, you could delete and reenter the entire SSH related information including the domain name, and zeroizing and reapplying the RSA key. After that, reload the device...
iamrobbormai
Maybe this will help someone else in the future. I saw something similar upgrading 16.3 to 16.9.4. We had passwords saved as secret 4. The stack I updated at this level removed the user during the upgrade process. I tested on a different stack and found if I recreated the user and the password was at secret 5, the user was not removed during the upgrade process.
I too was able to access the switch via the console to add the users after they were removed during upgrade.
That is an interesting observation, that the behavior might be related to users with secret 4. Thanks for sharing it. +5 for the contribution.
Rick
Rick
vishal.c07
Hello everyone,
Problem: Not able to login into Cisco Switch after firmware upgrade
Symptoms:
I've faced same issue, after troubleshooting I've found that user or enable password with "secret 4" encryption are getting vanished after firmware upgradation
Example : username admin privilege 15 secret 4 *******
Solution: Reconfigure username password before upgradation and make sure it is not "secrete 4"
Note: SNMP configuration also vanish in my case.
Vishal
vishal.c07
Hello everyone,
Symptoms:
Vishal
