02-27-2017 03:03 PM - edited 03-05-2019 08:06 AM
I have a customer who is having trouble opening a few websites - three that they have noticed so far. They are each secure sites and I am completely at a loss as to what is going on here. The setup is AT&T fiber box into the 0/0 of the Cisco 2811 with a /30. Their is a 4ESW WIC card in the 2811 to act as a DMZ for the AT&T LAN /29 block.
I know this is not an AT&T routing issue or an issue with the IP's as I can put a laptop directly on the /30 into the fiber box and pull the websites up fine. I have also put a basic Linksys router in place of the 2811 and was able to browse fine off of any of the public IP's. Also, this seemed to have randomly started about two weeks ago. It has worked fine before that.
Config is as follows:
version 12.4
service password-encryption
hostname router
boot-start-marker
boot-end-marker
card type t1 0 3
logging message-counter syslog
aaa new-model
aaa authentication login default local
aaa authentication login userauthen local
aaa authorization exec default local
aaa authorization network groupauthor local
aaa session-id common
clock timezone PST -8
clock summer-time PST recurring
network-clock-participate wic 3
network-clock-select 1 T1 0/3/0
dot11 syslog
ip source-route
ip cef
ip domain name cctonline.net
ip name-server 68.94.156.1
ip name-server 68.94.157.1
no ipv6 cef
isdn switch-type primary-ni
voice rtp send-recv
voice service pots
voice service voip
 allow-connections sip to sip
 signaling forward unconditional
 fax protocol cisco
voice-card 0
 dspfarm
 dsp services dspfarm
username XXXXX
username XXXXX
username XXXXX
archive
 log config
 hidekeys
controller T1 0/3/0
 cablelength short 110
 pri-group timeslots 1-24
controller T1 0/3/1
 cablelength long 0db
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 1
class-map match-any voip-control
 match ip dscp cs3
class-map match-any voip-rtp
 match ip dscp ef
class-map match-any vodex-voip-policy
 match access-group name Vodex_VOIP_Control
 match access-group name Vodex_VOIP_RTP
 match access-group name DNS_Servers
policy-map voip-priority
 class voip-rtp
 priority percent 70
 set dscp ef
 class voip-control
 priority percent 5
 set dscp cs3
 class class-default
 fair-queue
 random-detect
policy-map vodex-voip-policy
 class vodex-voip-policy
 priority percent 90
 set dscp ef
 class class-default
 fair-queue
 random-detect
interface FastEthernet0/0
 ip address x.x.x.x 255.255.255.252
 ip access-group Firewall_In in
 ip virtual-reassembly
 duplex auto
 speed auto
 no cdp enable
 max-reserved-bandwidth 90
 service-policy output vodex-voip-policy
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
 no cdp enable
interface FastEthernet0/2/0
interface FastEthernet0/2/1
interface FastEthernet0/2/2
interface FastEthernet0/2/3
interface Serial0/3/0:23
 no ip address
 encapsulation hdlc
 isdn protocol-emulate network
 isdn incoming-voice voice
 isdn supp-service name calling
 no cdp enable
interface Vlan1
 ip address x.x.x.x 255.255.255.248
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 x.x.x.x
no ip http server
no ip http secure-server
ip access-list extended DNS_Servers
 permit udp host 4.2.2.1 eq domain any
 permit udp host 4.2.2.2 eq domain any
 permit udp host 4.2.2.3 eq domain any
 permit udp host 4.2.2.4 eq domain any
 permit udp host 4.2.2.5 eq domain any
 permit udp host 4.2.2.6 eq domain any
 permit udp host 8.8.8.8 eq domain any
 permit udp host 8.8.4.4 eq domain any
 permit udp host 66.52.116.2 eq domain any
 permit udp host 66.52.116.3 eq domain any
 permit udp host 208.74.8.115 eq domain any
 permit udp host 199.187.232.6 eq domain any
 permit udp any host 4.2.2.1 eq domain
 permit udp any host 4.2.2.2 eq domain
 permit udp any host 4.2.2.3 eq domain
 permit udp any host 4.2.2.4 eq domain
 permit udp any host 4.2.2.5 eq domain
 permit udp any host 4.2.2.6 eq domain
 permit udp any host 8.8.8.8 eq domain
 permit udp any host 8.8.4.4 eq domain
 permit udp any host 66.52.116.2 eq domain
 permit udp any host 66.52.116.3 eq domain
 permit udp any host 208.74.8.115 eq domain
 permit udp any host 199.187.232.6 eq domain
ip access-list extended Firewall_In
 permit udp 8.14.139.0 0.0.0.255 any eq 1720
 permit tcp 8.14.139.0 0.0.0.255 any eq 1720
 permit udp 8.14.139.0 0.0.0.255 any eq 2517
 permit tcp 8.14.139.0 0.0.0.255 any eq 2517
 permit udp 8.14.139.0 0.0.0.255 any eq 5060
 permit tcp 8.14.139.0 0.0.0.255 any eq 5060
 permit udp 8.14.139.0 0.0.0.255 any eq 5061
 permit tcp 8.14.139.0 0.0.0.255 any eq 5061
 deny udp any any eq 1720
 deny tcp any any eq 1720
 deny udp any any eq 2517
 deny tcp any any eq 2517
 deny udp any any eq 5060
 deny tcp any any eq 5060
 deny udp any any eq 5061
 deny tcp any any eq 5061
 permit ip any any
ip access-list extended Vodex_VOIP_Control
 permit udp host 8.14.139.68 eq 5060 any
 permit udp host 8.14.139.8 eq 5060 any
 permit udp any host 8.14.139.68 eq 5060
 permit udp any host 8.14.139.8 eq 5060
 permit udp 208.86.44.160 0.0.0.15 eq 5060 any
 permit udp any 208.86.44.160 0.0.0.15 eq 5060
ip access-list extended Vodex_VOIP_RTP
 permit udp host 8.14.139.68 range 40000 40301 any
 permit udp any host 8.14.139.68 range 40000 40301
 permit udp any host 8.14.139.11 range 3000 65535
 permit udp any 8.14.139.12 0.0.0.3 range 3000 65535
 permit udp any host 8.14.139.16 range 3000 65535
 permit udp any host 8.14.139.20 range 3000 65535
no cdp run
So far I have tried entering the "ip tcp adjust-mss 1452" as well as "no ip source-route" commands
Thanks for the help in advance!
02-28-2017 12:01 AM
On the vlan1 interface try adding:
ip tcp adjust-mss 1400
