08-23-2011 09:49 AM - edited 03-04-2019 01:22 PM
I have a pinging problem. I have this cfg.
Webservice PC --> 6506 switch ---> cisco1 3750 --> cisco2 3750 ---> PC1
here the cfgs for each device and I removed some of the extra stuff.
Cfg on cisco 6506 Sup720
Router#sho run
Building configuration...
Current configuration : 13415 bytes
upgrade fpd auto
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service counters max age 5
hostname Router
boot-start-marker
boot system disk0:s72033-adventerprisek9_wan-mz.122-33.SXH8.bin
boot-end-marker
no aaa new-model
firewall module 1 vlan-group 1,
firewall vlan-group 1 20,40,99-102,105,106,110,112,114-117,122,200,220,240
firewall vlan-group 1 260,280,900
call-home
alert-group configuration
alert-group diagnostic
alert-group environment
alert-group inventory
alert-group syslog
ip subnet-zero
ipv6 mfib hardware-switching replication-mode ingress
vtp domain casta
vtp mode transparent
no mls acl tcam share-global
mls netflow interface
no mls flow ip
no mls flow ipv6
mls cef error action freeze
redundancy
keepalive-enable
mode sso
main-cpu
auto-sync running-config
spanning-tree mode pvst
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
fabric timer 15
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface GigabitEthernet2/1
switchport
switchport access vlan 100
interface GigabitEthernet4/48
switchport
switchport access vlan 20
interface Vlan1
no ip address
shutdown
interface Vlan100
ip address 10.94.8.3 255.255.255.0
ip classless
no ip http server
no ip http secure-server
control-plane
dial-peer cor custom
end
FWSM cfg on 6506
FWSM# sho run
: Saved
FWSM Version 4.1(3)
hostname FWSM
names
dns-guard
interface Vlan20
nameif outside_intf
security-level 1
ip address 192.10.10.2 255.255.255.0
interface Vlan100
nameif ssr_intf
security-level 85
ip address 10.94.8.2 255.255.255.0
ftp mode passive
access-list ssr_acc extended permit icmp any any
access-list outside_acc extended permit icmp any any
access-list outside_acc extended permit tcp 192.4.3.0 255.255.255.0 host 192.4.3.198 eq www
access-list acl_8_72_its extended permit ip host 10.94.8.72 10.17.18.0 255.255.255.0
mtu outside_agencies_intf 1500
no failover
icmp permit any outside_intf
icmp permit any ssr_intf
no asdm history enable
arp timeout 14400
nat-control
static (ssr_intf,outside_intf) 192.4.3.198 access-list acl_8_72_its
access-group outside_acc in interface outside_intf
access-group ssr_acc in interface ssr_intf
route outside_intf 10.17.18.0 255.255.255.0 192.10.10.1 1
route outside_intf 192.4.3.0 255.255.255.0 192.10.10.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 1:00:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-invite 0:03:00 sip-disconnect 0:02:00
timeout pptp-gre 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
service reset no-connection
no service reset connection marked-for-deletion
telnet timeout 25
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect skinny
inspect smtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:a59e4642acbb0f6088718f17589debcf
: end
Cisco1 3750 cfg
Current configuration : 2674 bytes
version 12.2
no service pad
hostname Switch3750
enable secret 5 $1$DRPb$BBo.k0ObFuw/g//mkiIvo0
enable password 7 1307121B1F1F557C
no aaa new-model
switch 1 provision ws-c3750g-12s
system mtu routing 1500
ip subnet-zero
ip routing
no file verify auto
vlan 20
name outside
vlan 110
name its
interface GigabitEthernet1/0/5
switchport mode access
interface GigabitEthernet1/0/6
switchport access vlan 110
interface Vlan20
ip address 192.10.10.1 255.255.255.0
interface Vlan110
ip address 192.4.3.2 255.255.255.0
ip classless
ip route 10.17.18.0 255.255.255.0 192.4.3.1
ip route 192.4.3.198 255.255.255.255 192.10.10.2
ip http server
control-plane
line con 0
end
Cisco2 3750 cfg
All I know is the port connected to Cisco1 3750 is 192.4.3.1. We do not manage this switch.
I cannot ping 192.4.3.1 on Cisco2 from the FWSM on the 6506. I can ping 192.4.3.2 on Cisco1. I can
ping 192.10.10.2 on the 6506 and 192.4.3.1 on the Cisco2 from Cisco1. I'm not sure why I can ping from
Cisco1 to Cisco2 but not from the 6506 to Cisco2.
Also I can ping 192.4.3.2 on Cisco1 from the 6506.
Can anyone see anything wrong with my configuration? Is the ping being blocked by the fwsm?
It's been a while since I've done this, plus I wan't that great to begin with so Any help would be appreciated.
It's probably something easy I forgot to do or something, but I can't seem to figure it out.
And another side note. I can see the hitcnt for the
access-list outside_agencies_acc line 17 extended permit tcp 192.3.3.0 255.255.255.0 host 192.3.3.198 eq www
going up but they say that PC1 is not getting the data. I'm not sure if the data is not getting getting back to them.
I hook up another switch to simulate PC1 and Cisco2 and I able to access the webservice PC and get the data, but
I still wasn't able to ping 192.4.3.1. I hope this didn't add to the confusion. If I can figure out the ping problem this
might solve this other problem. One step at a time.
TIA
Mike
08-23-2011 10:43 AM
Hi Mike,
I am not familiar with FWSM config, but I do not see a default route on the 6506 or the FWSM.
On the 6506 need a default route:
ip route 0.0.0.0 0.0.0.0 10.94.8.2 (the FWSM interface)
on the FWSM you need a default route
route outside 0.0.0.0 0.0.0.0 192.10.10.1 (37501 interface)
and test again
08-23-2011 12:41 PM
our FWSM has a default ip route already to some other network. It's hard to figure out exactly what's going on when you don't have the configuration of the other Cisco2 3750 switch. if you look below I hooked up a 3550 cisco switch to emulate the Cisco2 3750. But I can't seem to get that configured correctly either.
08-23-2011 11:13 AM
Mike
I may be missing them but could you provide IPs of the webserver and the PC ?
Jon
08-23-2011 12:09 PM
The Webserver PC in 10.94.8.72 which is nat'd to 192.4.3.198. The PC1 ip address is 10.17.18.103 but I ASSUME it is some how routed to 192.4.3.1. I had set up my own test lab right now and I hooked up a Cisco 3550 where I configured the port.
vlan 110
name its
interface FastEthernet0/1
no ip address
interface FastEthernet0/5
no ip address
interface Vlan100
ip address 10.17.18.1 255.255.255.0
interface Vlan110
ip address 192.4.3.1 255.255.255.0
ip classless
ip route 10.17.18.103 255.255.255.255 192.4.3.2
I have no default route which might be the problem.
What I did find out is that with the config i did for the 3550 the PC can't ping the default gateway (10.17.18.1) when I connect the 3550 to the 3750 switch. if I unplug the 3750 from the 3550 I can ping the gateway from the PC. I figure that routing the traffic from 10.17.18.103 to 192.4.3.2 somewhere the path gets lost.
08-23-2011 01:35 PM
Mike
The web server is only natted to 192.4.3.198 when the destination subnet is 10.18.19.0
access-list acl_8_72_its extended permit ip host 10.94.8.72 10.18.19.0 255.255.255.0
but you said the PC is 10.17.18.103 ???
Jon
08-23-2011 02:14 PM
Sorry about that. I usually double check my ip addresses because they're important. All subnet are 192.10.10.xxx, 10.17.18.xxx, 192.4.3.xxx and 10.94.8.xxx.
Oh and on the 3550 switch I removed the ip route 10.17.18.103 255.255.255.255 192.4.3.2 because i realized that I'm trtrying to access 192.4.3.198 and I don't need to route it. I got confused with routing the ip of the PC instead of the subnet traffic the PC is trying to access.
I also added
access-list outside_acc extended permit tcp 10.17.18.103 255.255.255.255 host 192.4.3.198 eq www
to the FWSM and my test network works.
I've done more testing and I really just need to know why I can't ping from the FWSM to any of the switches connect to the Cisco1 3750 switch. I can ping most devices connected to the Cisco1 3750 from the Cisco1 3750, but I can't ping any of the them from the FWSM. My probelm seems to be between the FWSM and the how traffic gets to the next hop. I can ping 192.4.3.2 on Cisco1 but not 192.4.3.1 on Cisco2. But I can ping 192.4.3.1 on Cisco2 from Cisco1.
Any help would appreciated. Maybe a thought or something to test.
