can't ping router from a different network
koalabear
your devices had no default gateway configured, the laptop on the left did not even have an IP address. I also configured RIPv2 on your routers. Find attached the revised file with end to end connectivity...
6 Replies 6
is this a simulation (e.g. Packet Tracer) ? Post the configs of both routers...
I'm suspecting that it has to do with the routing table? because the packets get lost when I try to ping router 1. Thank you!
post the (zipped) .pkt file...
here you go!
thank you^^
thank you so much! it works now!
