03-16-2020 12:45 AM
Hello there please help me, I'm learning about ACL and using the standard in the trials that I do. I think it works but it's different from what I expected, I want the server to ping the client but the client can't ping the server and what I get is that the server and client won't ping each other. Anyone can tell me what's wrong, I'm very confused. This is the topology that I made, please check.
Solved! Go to Solution.
03-16-2020 01:44 AM
you could configure CBAC (Context Based Access Control) on R2. The config would look like below (important parts marked in bold). The revised .pkt file is attached.
Building configuration...
Current configuration : 827 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
ip inspect name ICMP icmp timeout 10
spanning-tree mode pvst
interface FastEthernet0/0
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 12.12.12.2 255.255.255.252
ip access-group BLOCK_ALL in
ip inspect ICMP out
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
ip route 192.168.1.0 255.255.255.0 12.12.12.1
ip flow-export version 9
ip access-list extended BLOCK_ALL
deny ip any any
line con 0
line aux 0
line vty 0 4
login
end
03-16-2020 01:32 AM
i do not have packet tracer to test your Zip file.
you can use established syntax for who intiate the connection
Look at the example :
03-16-2020 01:44 AM
version 12.4
hostname Router
ip cef
no ipv6 cef
duplex auto
speed auto
ip inspect ICMP out
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
deny ip any any
line con 0
line aux 0
line vty 0 4
login
end
03-16-2020 02:19 AM
Cam you give me ScreenShots Sir?
03-16-2020 02:32 AM
Thank you, sir, for your help
