Can't PING/send PDU from wired PC on wired router to wireless devices
Ammar Ramadhan
Hello all,
I have an issue where i can't ping any device (in my case, the device is laptop with wireless module) from PC connected to router.
i have 4 laptops with wireless module and the default gateway is 192.168.30.1 connected to wireless home router, and the home router connected using copper cross-over cable to fa1/0 interface on router1 with IP 192.168.30.1. the problem is, any PC connected to router1 and router0 on the other side cannot PING those laptops. I have watched a video in youtube and follow the step carefully, but looks like i miss something because the different version of Packet Tracer.
i attach my work, so anyone can see, and find the problem. thanks for responding.
Martin L
Wireless Home Router has always given us issues; It should work one way only; I mean you could go out if wireless laptops initiated traffic to outside but not other way around (just like home wireless router and i think it always worked that way in PT).
Last week we had similar post about this set up; I think pings were going outside but not other way around. My recommendation was to check Net Academy or Refer to PT Help menu if you can change some settings.
Regards, ML
**Please Rate All Helpful Responses **
Martin L
Regards, ML
