Can't ping the only router in my network with a loopback address
raphar_s
Hello everyone.
Every ping I send to my first router fails. Everything else can ping anything it's directly connected to, but nothing can ping the router on the right with the loopback address.
Since that's its only particular characteristic, I'm guessing it's something to do with the loopback ? Can someone give me some pointers here because I'm quite befuddled.
raphar_s
I tried running these two commands on my router, only
show ip route
worked, wich gave this result :
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
192.168.1.0/24 is variably subnetted, 4 subnets, 3 masks
C 192.168.1.0/26 is directly connected, Loopback0
L 192.168.1.1/32 is directly connected, Loopback0
C 192.168.1.80/30 is directly connected, GigabitEthernet0/0/1
L 192.168.1.81/32 is directly connected, GigabitEthernet0/0/1
192.169.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.169.1.64/29 is directly connected, GigabitEthernet0/0/0
L 192.169.1.65/32 is directly connected, GigabitEthernet0/0/0
Which is weird, since I didn't set anything up on 192.169.x.x... Also, I've attached the zipped .pkt file, as requested.µ
EDIT : turns out, I DID setup an address on 192.169.x.x by mistake, and now things works. Sorry for the disturbance.
 It depends.  Can you share two command?:
show run int loopback
show ip route
also, post your zipped Packet Tracer project (.pkt) file...
raphar_s
show ip route
