catalyst 3650 debug not working
jahangir.ma
debug
command not working on catalyst 3650 switch, it doesn't show any thing after on.
 If you are loggin into the switch using network connection, after
debug
command you need to use
 terminal monitor
command in order to see the logs on screen.
If you are using console connection, it should log automatic.
debug
 terminal monitor
The suggestion about
terminal monitor
is a good one. You should also check the configuration and see if logging severity levels have been configured, and if so does the severity level chosen suppress the debugging messages. The output of the first page or so of output of
show log
should provide information about logging levels if you are not sure what the operational levels are.
Rick
