Can't ping the WAN when NAT and DHCP are both working
My topology :
My configuration :
R1 :
BOX1#sh run
Building configuration...
Current configuration : 2022 bytes
version 12.4
hostname BOX1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip dhcp use vrf connected
ip dhcp pool BOX
network 192.168.0.0 255.255.255.0
default-router 192.168.0.20
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip tcp synwait-time 5
interface FastEthernet0/0
ip address 223.0.1.2 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface FastEthernet1/0
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
no ip address
router ospf 1
log-adjacency-changes
network 223.0.1.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http server
no ip http secure-server
ip nat inside source list BOX1 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.0.2 80 223.0.1.2 80 extendable
ip access-list standard BOX1
permit 192.168.0.0 0.0.0.255
no cdp log mismatch duplex
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R2 :
BOX2#sh run
Current configuration : 1951 bytes
version 12.4
hostname BOX2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip dhcp pool BOX
default-router 192.168.0.25
no ip domain lookup
ip address 223.0.0.2 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip nat inside
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Vlan1
no ip address
router ospf 1
network 223.0.0.0 0.0.0.255 area 0
no ip http server
ip nat inside source list BOX2 interface FastEthernet0/0 overload
ip access-list standard BOX2
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R3 :
BORDER_ROUTER#sh run
Current configuration : 1643 bytes
version 12.4
hostname BORDER_ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip address 223.0.1.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip address 223.0.0.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Vlan1
no ip address
router ospf 1
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
WEBTERM config auto eth0WEBTERM config auto eth0TOOLBOX config au eth0TOOLBOX config au eth0Ping_WAN_WEBTERM.PNGPing_WAN_ToolBox.PNG
I use the OSPF for routing and all ping between the routers is succed.
Thank's for help :)
since the FastEthernet00/0 interfaces on R1 and R2 have static IP addresses, the default routes won't work. If you need default routes, configure them as below:
R1
--> no ip route 0.0.0.0 0.0.0.0 dhcp
ip route 0.0.0.0 0.0.0.0 223.0.1.1
R2
ip route 0.0.0.0 0.0.0.0 223.0.0.1
Hi My friend I'm sorry for late,
even if I did all the changes, the problem persists, now I can ping the toolBox from the webterm but if I try to access to the the toolBox from the webterm using the navigator (MOZILLA) i can't !!!
Idon't know where's the problem :(
R1 :
BOX1#sh run
Current configuration : 2071 bytes
version 12.4
hostname BOX1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip dhcp excluded-address 192.168.0.20
ip dhcp pool BOX
no ip domain lookup
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip address 192.168.0.20 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Vlan1
no ip address
router ospf 1
no ip http server
ip nat inside source static tcp 192.168.0.1 80 interface FastEthernet0/0 80
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R2 :
BOX2#sh run
Current configuration : 1995 bytes
version 12.4
hostname BOX2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip dhcp excluded-address 192.168.0.25
ip dhcp pool BOX
no ip domain lookup
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip address 192.168.0.25 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Vlan1
no ip address
router ospf 1
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
TOOLBOX :
When I ping the R3 int f0/0 it works :
TOOLBOX.PNG------------------------------------------------------
WEBTERM :
But when I try to ping th esame destination from mozilla navigator which included on the webterm it isn't works !
I don't know what's the problem :(
Hi @Georg Pauwen,
finally it's working :)
i just changed the toolbox and reconfigure it, Thank you @Georg Pauwen.NETWORKER's.PNG
