04-28-2021 05:29 AM
For my study i need to design a small network with 2 different subnets that can communicate with eachother.
PC1 has the ip address: 10.38.192.5 255.255.192.0
PC2 has the ip address: 10.38.0.5 255.255.192.0
The routers are configured with RIPv2.
Router0 has the ip: 11.1.1.1/18
Router1 has the ip: 12.1.1.1/18
Router2 has the ip: 13.1.1.1/18
Any idea why i can't reach pc2 when i send a ICMP request from pc1?
Solved! Go to Solution.
04-28-2021 08:45 AM
what is the Gateway of each device :
Since we do not have configuration or configured on the device hard to say where it gone wrong ?
You IP address not part of RIPv2 network, so there may be (guessing )this network required to anounce respected router to propogate all over network.
Test :
PC 1 what is the gatway , are you able to Ping Gateway ( where is the Gateway reside ( in switch or Router) ?
Traceroute from PC1 to PC 2 IP see where it stop, that is best to start with.
04-28-2021 08:45 AM
Test :
04-28-2021 08:58 AM
04-29-2021 12:24 AM
PC1 has the 10.38.192.1 gateway. I am able to ping the gateway.
04-28-2021 11:25 AM
Please zip your PT file and attach it here.
Regards, ML
**Please Rate All Helpful Responses **
04-29-2021 12:23 AM
