Can't remove a static route...
rudepeople
This question has been asked in this discussion, but the post has gone stagnant without resolution...
I have an old static route configured on my IRS4321k9 that I put in during testing. Now that the router is deployed, I want to remove the old route but it doesn't seem to want to remove...
I ran no ip route 0.0.0.0 0.0.0.0 172.8.8.22
No errors... exit, wr, then sh run and the route is still there...
sh ip route doesn't list it, but is shows up in sh run... what's the voodoo I need to kill it or is it just a phantom entry in sh run?
here's my sh ip route (obvious fake IPs are fake):
router#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 172.10.0.33 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 172.10.0.33
      192.168.60.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.60.0/24 is directly connected, Vlan1
L        192.168.60.1/32 is directly connected, Vlan1
      172.10.0.0/24 is variably subnetted, 2 subnets, 2 masks
C        172.10.0.32/28 is directly connected, GigabitEthernet0/0/0
L        172.10.0.36/32 is directly connected, GigabitEthernet0/0/0
router#
5 Replies 5
odd indeed. Is the route also in the startup config (show startup-config) ? If so, your best option is probably to copy the startup config to a TFTP server, edit the text file and remove the static route, TFTP it back to the router, and then copy the startup to the running config...
Yep, it's in startup config as well. I guess I'm going to have to build a tftp server next... *sigh*... this is in a colo, so this'll be fun.
I am puzzled by the reported symptoms and would like to see some more detail about it. Would you post the output of these steps:
show run | include route
show ip route
the config commands to remove the static route
Rick
Rick
router1#show run | include route
 default-router 192.168.60.1
ip route 0.0.0.0 0.0.0.0 172.8.8.69
ip route 0.0.0.0 0.0.0.0 172.8.0.33
router1#
show ip route
router1#sh ip route
Gateway of last resort is 172.8.0.33 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 172.8.0.33
      206.71.85.0/24 is variably subnetted, 2 subnets, 2 masks
C        172.8.0.32/28 is directly connected, GigabitEthernet0/0/0
L        172.8.0.36/32 is directly connected, GigabitEthernet0/0/0
router1#
Specifically:
router1> enable
router1# config t
router1 (config)# no ip route 0.0.0.0 0.0.0.0 172.8.8.22
router1 (config)# exit
router1# wr
same thing:
router1#
I'll have a tftp server up in a few minutes so I'll pull the startup-config, manually remove it, reup the config, and reboot... that'll fix it for sure. but yeah! WTH?!
Thank you for the information that I requested. It does show what you described. Can we verify that the lines of ip route 0.0.0.0 are in global config mode, or perhaps in some other mode? Can you post a page of show run preceding the ip route 0.0.0.0 and a half page of output following them? (or perhaps just the whole config)
Rick
Rick
