12-19-2011 05:46 AM - edited 03-04-2019 02:41 PM
Hey there, guys!
Today I've met problem. I have Cisco router 851 at my region site. It has five Fa ports. One of them is connected to ISP and has ip address 10.1.1.2 (for example). It also has vlan 1 interface, that has ip address 192.168.0.1 (also for example). I also have Tun0 interface that goes through ISP network and connects to my hub network. The rest of Fa interfaces are swithcable and they are in vlan 1.
The problem is that from hub LAN I can telnet to 10.1.1.2 ip address, but I can't telnet to 192.168.0.1. Whereas I can Ping 192.168.0.1 from my hub LAN.
Anyone has any ideas ?
Topology:
Hub LAN -------ISP---------Spoke Router 851
Mike
12-19-2011 06:04 AM
Is there any acl applied to any interface or vty line ?
12-19-2011 06:13 AM
Hi Mike,
As Marwan said, there must be some access-group applied to the line vty interface and your 10.1.1.0 netork may not be permitted in that access-list. Please check that and let us know if you still facing any issues.
The applied access-group looks like below...
line vty 0 4
 access-class 23 in
 login authentication device
 transport input ssh
access-list 23 permit 193.168.0.0
Please rate the helpfull posts.
Naidu.
12-19-2011 12:03 PM
Thanks for quick response!
1st - there're No ACL for physical interfaces.
2nd - there is access-group for vty acces for several hosts from network "hub LAN"
Anyway I am able to connect to interface 10.1.1.2, so access group works fine for telnet connection. I just can't connect to 192.168.0.1:
line vty 0 4
access-class 99 in
privilege level 15
transport input ssh
access-list 23 permit 192.168.0.250 - host for example
aaa new-model is ON - maybe it is not so neccesary but still.
Also there is NO NAT configuration there.
And Bug Toolkit for current IOS showed nothing related to this problem.
Tomorrow I'll be able to post whole configuration of this router here...
Mike
12-19-2011 02:25 PM
line vty 0 4
access-class 99 in
privilege level 15
transport input ssh
Mike
Is the SVI actually up?
The device won't put interface VLAN1 in up/up state unless there is a port (access or trunk) assigned to that VLAN and in the up/up state also. And if interface VLAN1 is not up, then you obviously won't be able to telnet to its IP address.
If you can telnet into the 10.1.1.2 address, what is the output when you do
show interface vlan1
from the command line?
Cheers.
12-19-2011 10:12 PM
Darren, please read the initial post carefuly:
Four Fa interfaces are in vlan 1, and in SVI is UP. Also I can Ping 192.168.0.1.
Here you go:
sh inter vl 1
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 0023.332e.20cd (bia 0023.332e.20cd)
Description: LAN
Internet address is 192.168.0.1/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Last input 00:00:34, output never, output hang never
Last clearing of "show interface" counters 4d18h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1323067 packets input, 260065941 bytes, 0 no buffer
Received 3264 broadcasts, 0 runts, 0 giants, 0 throttles
1573058 packets output, 1003872276 bytes, 0 underruns
0 output errors, 0 interface resets
Whole router config:
version 12.4
no service pad
service password-encryption
hostname Spoke
boot-start-marker
boot-end-marker
logging buffered 4096
aaa new-model
aaa session-id common
clock timezone MSK 4
crypto pki trustpoint TP-self-signed-723587833
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-723587833
 revocation-check none
 rsakeypair TP-self-signed-723587833
dot11 syslog
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1
ip dhcp pool LAN
   network 192.168.0.0
   dns-server xxxxxxxx
   domain-name xxxxxxxxx
   default-router xxxxxx
   netbios-node-type h-node
   netbios-name-server xxxxxxx
ip cef
no ip domain lookup
username 111 privilege 15 secret 5 111
crypto isakmp policy 2
 encr aes
 hash md5
 authentication pre-share
 group 2
crypto isakmp key xxxxxxxx address xxxxxxxx
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto map lan2lan 100 ipsec-isakmp
 set peer xxxxxxxxx
 set security-association lifetime seconds 28800
 set transform-set ESP-AES-128-MD5
 set pfs group2
 match address l2l
archive
 log config
  hidekeys
ip tftp source-interface Vlan1
interface Loopback0
 no ip address
interface Tunnel0
 description Tunnel
 bandwidth 2048
 ip address 172.16.0.2 255.255.255.252
 keepalive 3 3
 tunnel source 10.1.1.2
 tunnel destination 10.1.1.1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
 bandwidth 2048
 ip address 10.1.1.2 255.255.255.252
 speed 100
 full-duplex
interface Vlan1
 description LAN
 ip address 192.168.0.1 255.255.255.0
 ip flow ingress
 ip flow egress
 ip tcp adjust-mss 1300
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Tunnel0
ip flow-top-talkers
 top 50
 sort-by bytes
ip http server
ip http access-class 99
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip access-list extended l2l
 permit ip xxxxxxxxxx 0.0.0.15 any
ip sla responder
ip sla 1
 udp-jitter xxxxxxxx 16890 source-ip 192.168.0.1 codec g729a
ip sla schedule 1 life forever start-time now
access-list 99 permit 192.168.0.250
snmp-server community xxxxxx RW 50
snmp-server community xxxxxx RO 51
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 access-class 99 in
 privilege level 15
 transport input telnet ssh
scheduler max-task-time 5000
sntp server xxxxxxx
end
12-20-2011 12:45 AM
line vty 0 4
access-class 99 in
The only src IP address that can telnet into the router is 192.168.0.250.
What is the src IP when coming from the HuB Network ?
Regards.
Alain
12-20-2011 12:51 AM
Alain, src ip of host is 192.168.0.250 -)
I believe that acl is not a point of failure here, cuz I am able to telnet to 10.1.1.2
12-20-2011 03:27 AM
ok so can you do a sh crypto ipsec before and after the telnet and if you see no more packet counter increase can you
verify your crypto ACL on both sides.
Regards.
Alain
