Can't type anything in router console.
GlobalC
Hello.
So, i connected Cisco 892fsp console to PC, with an USB adapter for DB9.
I See the boot log of this router, but when it comes to "Would you like to enter the initial configuration dialog? [yes/no] "
I can't type anything in the answer...
Any ideas?
8 Replies 8
which terminal emulation software are you using ?
I tried Putty and also i tried HyperTerminal.
is this a new device ? Try and do a reset to factory defaults:
https://dcloud-cms.cisco.com/help/reset-router
It was on default. I did a reset before i started this thread. But there was no configuration in cisco router after reset.
After I got a computer with db9 port, it worked.
Thank you guys anyway!
Thanks for the update letting us know that the problem was with the adapter. Glad that you were able to find the solution to your own problem. A well deserved +5 for providing the solution.
Rick
putty - try Flow control to NONE and let us know.
BB
Had this issue, found this thread, your reply helped me thanks!
Glad its helpful.
BB
