09-07-2014 04:41 PM - edited 03-04-2019 11:42 PM
Can a switch 2950 be functional with the IOS universalk9-mz.SPA.151-4.M2.bin?
The coorporate where I work have one of these switches, and this device had been showing network issues.
Tried to find at cisco portal the IOS, but couldn´t find much info (since is a life-end-supported device).
Any help will be appreciated.
Patricia Ramirez
09-07-2014 06:08 PM
You won't be able to load that sort of software on a 2950. Not enough flash, DRAM and CPU power.
09-07-2014 07:36 PM
Just had a look u cant.
09-08-2014 08:50 AM
The device already has this IOS image installed (flash0:c2951-universalk9-mz.SPA.151-4.M2.bin).
For some unknown reason, this device has been configured to be used as a router. My doubt is if a switch can be used to work as router (connection to carrier, bgp session, etc)?
09-08-2014 05:37 PM
The 2950 switch is a L2 switch only i'm afraid so no it will not be able to use as router.
09-08-2014 09:54 AM
09-09-2014 05:41 PM
Oh dear. I thought you were talking about an old Catalyst 2950 switch instead of a 2951 router.
What "switch" are you talking about?
