Showing results forĀ
Search instead forĀ
Did you mean:Ā
CAN WE CONNECT TWO SAME CITIES ROUTERS TO SINGLE MPLS ROUTER
AMANBHARDWAJ
CAN WE CONNECT TWO SAME CITIY CUSTOMER ROUTERS TO SINGLE MPLS ROUTER
FOR SAY CUSTOMER HAS TWO BRANCH OFFICES IN WORLI AND ANDHERI, YOU HAVE TO CONNECT THESE TWO CUSTOMER OFFICES VIA SINGLE MPLS ROUTER OF MUMBAI LOCATION.
5 Replies 5
I don't see why that is not possible. You need an MPLS circuit from both branch offices to the Mumbai office, a single router can terminate both circuits. Then again, since that answer seems to easy, I am probably missing something. What are you running into exactly ? What router(s) do you have at the branches and the main office ?
Hello Georg Pauwen,
The two offices of customer are actually the two independent departments (one is their Warehouse and other is the R&D department) and they have asked for MPLS L3 services from the ISP. And being an ISP we are exploring the feasibility of giving services to them with our single MPLS router.
connectivity  attached for better understanding
How are the two customers currently terminating ? Either way it should not be a problem.
AMANBHARDWAJ
how mpls will work while RT will come in picture , export and import routes  for two different customers are imported and exported to same MPLS node. is this not a kindda rare or complex scenario
Harold Ritter
Hi @AMANBHARDWAJ ,
This is in fact a very common scenario. The PE is almost always shared between different customers. The routes from each customer will be loaded in a separate VRF, creating an isolation from other customers sharing the same PE.
