Bookmark
Subscribe
604
Connect to Different Sub-Networks with a Router
Can anyone please assist me on how to connect two subnetworks like given in the PKT here?
I have also attached a table including the IP Addresses and the question..
I have already completed task 1-3. Need help regarding the 4th one.
are these the full instructions ? There is no indication of how the routers are to be connected, through which interfaces, and which subnet is supposed to be used for which connection ?
@Georg Pauwen Thanks for reaching out. Yes, these are the full instructions. I have completed the other two sub networks and they work fine. I am just stuck with the 'Gotham' Part and what to do with it. You can use 192.168.24.1/22 or any other IP as per your liking in Gotham since the table is manually generated by me, so I can make further changes.
Hello @abdullah.al.sipon @Georg Pauwen
From looking at your current lap simulation setup and the VLSM table you have been provided, you need to readdress your topology correctly as presently it is incorrect.
Clue -
You have 6 /30 networks (L-1 to L-6) and to connect all your city rtrs together requires 6 interconnections
Kind Regards
Paul
@paul driver The VLSM table is randomly generated and I can update it as per my likings..
But to connect the sub networks to Gotham, which routers do I need to connect with it?
