Can we use Cisco Router 2921 for BGP?
nguyenthinh
Dear all,
I want talk BGP with ISP though 200Mb/s WAN link by using Cisco Router 2921; and in the near future WAN link will be upgraded to 1Gb/s. Does Cisco Router 2921 has enough performance to do this task?
Thanks alot for your advice!
5 Replies 5
SOcchiogrosso
Level 4
Level 4
The 2921 is not really scaled for 200 MB of throughput you might want to look at a 3945e or an ASR 1001
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Cisco recommends the 2921 for up to 50 Mbps of WAN bandwidth.  Cisco recommendations are conservative, so it might manage your 200 Mbps link depending on how much bandwidth is actually used and your configuration, but for 1Gbps, you'll likely what something "faster".
BTW, the "fastest" ISR, the 3945E, is only recommended for 350 Mbps of WAN bandwidth.  So you might want to look at L3 switches (especially Metro Ethernet variants) or the ASR1K series.
nguyenthinh
Dear all,
@JosephDoherty and SOcchiogrosso : Thanks for your advice!
Can I use Cisco 3750G for that task?
Disclaimer
Posting
You might, although a 3750 won't be able to take full Internet BGP tables.
True, it won't be able. The 3750 with sdm desktop template of routing has a limit of 11 k routes: 8 k indirect + 3 k directly connected.
Best Regards,
Jose.
