Can you support two different DMVPN infrastructures?
ksvy_ksvy
question - to separate two DMVPN remote infrastructures, let's say one is for A remote sites and the other is for B remotes sites, we want A remote sites to use one key and B remotes to use a different key. Basically, can a DMVPN hub or duel DMVPN hub support two seperate - crypto isakmp key " " address 0.0.0.0 0.0.0.0 - policies statements?
devang_etcom
Level 7
Level 7
Yes you can have two tunnel at HUB and both are using different key to create two different NBMA cloud of DMVPN. You can terminate one Tunnel from HUB to site A and other tunnel from HUB to site B.
thanks,
Devang Patel
Devang, good, do you know of any white pages on how to do this?
thanks, Kevin
Kevin,
This link might be helpful to you:
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/ngwanedmvpn.pdf
thanks,
Devang Patel
Devang, excellent
thanks, Kevin
