cannot access remote lan cisco 881 easyvpn
Hello all
I can successfully establish a vpn connection using the cisco vpn client but i cannot access any resources on the remote site, nor can i ping anything.
The device running the EASYVPN server is cisco 881.
I would i appreciate some help here.
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp client configuration group GROUPVPN
 key Password1
 dns 10.10.10.1 8.8.8.8
 pool SDM_POOL_3
 acl 100
crypto isakmp profile ciscocp-ike-profile-1
   match identity group GROUPVPN
   client authentication list ciscocp_vpn_xauth_ml_3
   isakmp authorization list ciscocp_vpn_group_ml_3
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
 mode tunnel
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
 mode tunnel
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
 mode tunnel
crypto ipsec profile CiscoCP_Profile1
 set transform-set ESP-3DES-SHA2
 set isakmp-profile ciscocp-ike-profile-1
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Virtual-Template1 type tunnel
 ip unnumbered FastEthernet4
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
 ip address 10.10.10.1 255.255.255.0
 ip nat inside
ip local pool SDM_POOL_3 10.10.20.10 10.10.20.20
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 199 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx
access-list 100 remark CCP_ACL Category=4
access-list 100 permit ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
access-list 199 remark CCP_ACL Category=18
access-list 199 deny   ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
access-list 199 permit ip 10.10.10.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line vty 0 4
  transport input telnet
 transport output telnet
scheduler allocate 20000 1000
end
Raja Periyasamy
The configuration is good. The Nat exemption is configure as expected. Does not look like a configuration issue.
Check the default gateway on the host that you are tying to ping and make sure it is pointing to the router.
If it is a windows PC then check if windows firewall is enabled. That can cause issues.
On the Client PC make sure that the IP on the local adapter is not in the same subnet as that of the vpn pool.
