Cannot advertise networks in BGP?
jjevans1
Hello All,
I have a lab setup and I am trying to advertise the 192.168.30.X and 192.168.40.X networks from the C4331-Edge to the C2911-ISP-RTR
Also, I am trying to advertise the 75.75.75.X network from the C2911-ISP-RTR to the C4331-Edge-RTR.
I have tried no auto summary on both. Loopback interfaces on both. I have specifically added the mask on network statement but it does not show on the running config.
I am running out of ideas.
Any insight as to how I can advertise these routes will be greatly appreciated.
Thank you,
J
5 Replies 5
Martin L
is next hop reachable ?  Before a router does BGP process decision, it must check next hop. if it does not have a route to the next hop for your route x , it will reject such route.
Regards, ML
**Please Rate All Helpful Responses **
Yes I can ping the next hops interface in each direction on each of the opposing devices.
both router not advertise the same prefix appear in RIB, the ISR4000 and 2911 not advertise the prefix.
Harold Ritter
Hi @jjevans1 ,
For the BGP network statement to originate the route, there needs to be a perfect match between the network statement and a route in the routing table. For instance, on C2911-ISP-RTR you have two routes in the routing table for prefix 75.75.75.0, but one is with a /32 mask (lo0) and the other one is with a /26 mask (gi0/2), while the bgp network statement is with a /24 mask. There is no perfect match between statement and the routing table, so BGP does not originate the route. The solution is to add the following configuration under router bgp.
C2911-ISP-RTR:
router bgp 2003
network 75.75.75.75 mask 255.255.255.255
or
network 75.75.75.0 mask 255.255.255.192
C4331-Edge-RTR-A:
router bgp 1969
network 192.168.30.1 mask 255.255.255.255
network 192.168.40.1 mask 255.255.255.255
Hello
tou need to advertise the loopbacks with correct network mask - 255.255.255.255
Kind Regards
Paul
