Cannot apply Policy route-map to VLAN interface 3560G
mattwray
I have a 3560G that I cannot apply a policy route-map to one of the VLAN interfaces. I am running up to date software, c3560-ipservicesk9-mz.150-2.SE2 and it accepts the command, but does not show it in the sh run of the interface. I updated to this code as I had seen previously someone said it needed to be version 15 before you could apply route-maps to VLAN interfaces.
Any assistance would be greatly appreciated!!!
mvsheik123
Level 7
Level 7
Hi Matt,
Check if below works...
show sdm prefer --> See if any memory allocated to PBR (there may be none).
Issue the command - sdm prefer route  (write mem) and the reload the switch (make sure you have maintenance window, if this is production switch).
hth
MS
Thank you for the response, I have done this previously and it didnt help. That was what led me to believe upgrading the IOS might help.... The switch is in Desktop Routing mode and has memory allocated to PBR
My switch is running IP services image and I have already run the sdm prefer routing command and reloaded. I ended up moving the machine to a different VLAN to force the routing.
Thanks anyways
