cannot change interface speed and duplex on 828?
erwee1973
I ran into a strange problem. When I want to change the ethernet0 interface of a Cisco 828 sdsl router, but there is no command to do that in the interface configuration mode (speed 100 and duplex full).
A show interface gives 10MB half duplex and I want to change this.
This is the running config (a little censored):
interface Ethernet0
ip address 16.228.232.137 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
no keepalive
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip mroute-cache
no atm ilmi-keepalive
dsl equipment-type CPE
dsl operating-mode GSHDSL symmetric annex B
dsl linerate AUTO
pvc 0 8/48
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username xxx@xxxx.nl password 7 xxxxD0406595D3F
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
control-plane
line con 0
password 7 0202xxxxxx07C185B58
line vty 0 4
privilege level 15
password 7 14xxxxx147E6174
transport input telnet
scheduler max-task-time 5000
end
a show interfaces gives
Ethernet0 is up, line protocol is up
  Hardware is PQUICC Ethernet, address is 000d.bc58.8872 (bia 000d.bc58.8872)
  Internet address is
16.228.232.137/29
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
     reliability 255/255, txload 11/255, rxload 1/255
  Keepalive not set
  Half-duplex, 10Mb/s
How can I change this setting?
With kind regards,
Ralph Willemsen
John Blakley
Ralph,
Unfortunately, the interface is Ethernet and not FastEthernet. This is a 10Mb interface and can't be changed...
HTH,
John
HTH, John *** Please rate all useful posts ***
Richard Burts
Ralph
I believe that John is correct about the interface speed being limited to 10. There might be an option for duplex. And this might improve performance a bit.
Rick
Rick
