How to connect a 1811 w in a internet modem
kating_ph
Hi to all,
I am having  a hard time connecting my router into a internet modem since my modem is giving its own private ip address in short the modem is a router in itself. in addition, I cant change the modem's dchp pool its fix with 192.168.1.0 network. please help. thanks
Richard Burts
If the Internet modem is doing DHCP and can not be changed then perhaps you should try configuring your router interface to use DHCP to learn an IP address from the Internet modem
Rick
Rick
Richard Burts
Rick
Rick
Can i do private ip to  private ip natting? If i cant change also the router address. By the way the modem also used private ip for its client meaning it is automatically natted. Thanks for the reply
Richard Burts
I would think that private IP to private IP nat would work.
Rick
Rick
