01-30-2009 11:00 AM - edited 03-04-2019 01:03 AM
Here is my config.
aaa authentication login default local group tacacs+
aaa authorization console
aaa authorization config-commands
aaa authorization exec default local group tacacs+
aaa authorization network MONROE-IT local
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration address-pool local MONROEIT
crypto isakmp xauth timeout 60
crypto isakmp client configuration group MONROE-IT
key <pre-share key>
dns 10.1.0.121
domain lzb.hq
pool MONROEIT
acl 101
crypto ipsec transform-set transform-1 esp-3des esp-sha-hmac
crypto dynamic-map MONROE-IT 1
set transform-set transform-1
reverse-route
crypto map MONROE-IT client authentication list default
crypto map MONROE-IT isakmp authorization list MONROE-IT
crypto map MONROE-IT client configuration address respond
crypto map MONROE-IT 1 ipsec-isakmp dynamic MONROE-IT
interface FastEthernet0/0
ip address 12.XX.XX.3 255.255.255.128
duplex auto
speed auto
interface FastEthernet0/1
no ip address
ip flow ingress
duplex auto
speed auto
interface FastEthernet0/1.100
encapsulation dot1Q 100
ip address 10.1.0.10 255.255.240.0
no ip redirects
ip virtual-reassembly
router eigrp 555
network 10.1.0.0 0.0.15.255
network 10.251.1.10 0.0.0.0
no auto-summary
ip local pool MONROEIT 10.1.10.1 10.1.10.6
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet 0/0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
access-list 101 permit ip 10.1.10.0 0.0.0.255 any
I try to connect and the client says the remote end did not respond.
Solved! Go to Solution.
02-01-2009 09:31 AM
Try this:
Regards, Celio
02-01-2009 09:31 AM
Try this:
Regards, Celio
02-02-2009 07:57 AM
THANK YOU!!!
I spent all week last week looking at this issue and it never dawned on me to add this line.
Rick
